PO131 PO171 codes help! - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 03-22-2013, 11:37 AM   #1
Registered Member
BxTrini_TL's Avatar
Hey im getting codes PO131 PO171 also random misfire codes..when its warm out I get no cel and car runs fine no misfire.. It says bank1 sensor butI wanna be sure.. my tl is California emissions I saw denso sensors on eBay for a good price.. would they work? Or do I have to go to dealer cuz its California emissions? Anyone can help? Thanks I appreciate it..
BxTrini_TL is offline   Reply With Quote
Old 03-22-2013, 06:42 PM   #2
Registered Member
P0131>Primary O2 sensor reading low voltage could be a fuel supply problem. Check the fuel pressure. If ok, then check the sensor.
P0171>Fuel system too lean may be the fuel pump, filter, pressure regulator or EVAP purge control valve. If ok, then check misfire or sensor.
3.2TLc is offline   Reply With Quote
Old 03-25-2013, 01:58 AM   #3
Registered Member
BxTrini_TL's Avatar
Thanks Bro i will surely check those out..
Thread Thread Starter Forum Replies Last Post
Help Please!!! ABS and VSA light with exclamation point ALL ON Jamus22 2G TL Problems & Fixes 19 05-05-2016 09:58 AM
Error codes stored in messages MilanoRedDashR 3G TL Problems & Fixes 2 10-02-2015 11:49 AM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
Check Engine Light and P0683 Code mars First Generation TSX Discussion (2004-2008) 1 09-28-2015 12:03 PM
Tags
131, 2000, 2003, 32, acura, code, fuel, mdx, p0131, p0170p0171p0131, po131, po171po131, pressure, pulling, reasons, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
