No Cruise Control! - AcuraZine - Acura Enthusiast Community
No Cruise Control!
Thread Tools Search this Thread
Old 08-06-2009, 12:52 AM   #1
Registered Member
No Cruise Control!
Just picked up a 2002 TL S with 136K and promptly looked for a good Acura forum. This one looked like the best so I'm sure some one will come through.
There are a few minor (hopefully) things to fix on the car.
The first is the lack of cruise control. The little green light comes on when the cruise button on the dash is pushed but nothing happens when I push the set button on the steering wheel. Bad switch maybe?
The second is no indicator lights by the shifter. Is there a bulb to replace?
The last one is the radio asks for the code but nothing happens when you enter it. I already found a couple threads for this one so hopefully I can resolve it with the info there.
Thanks for the help.
IllinoisREI is offline   Reply With Quote
Old 08-06-2009, 08:29 AM   #2
fsttyms1's Avatar
Welcome to the forum..
Cruise. Does the Cruise control light up in your speedo cluster? If not with your let foot while driving take it and pull the brake up. Sometimes the brake switch needs adjusting replacing (also check that your brake lights work)
Yes just a light. Pop the covers off and get a needle nose pliers and pull the bulb out and replace it.
Radio, Try disconnecting the antenna from it then try entering the code.
fsttyms1 is offline   Reply With Quote
Old 08-06-2009, 02:49 PM   #3
2006 NBP TL MT6/ 02TL-S
AlanW's Avatar
Also, on the cruise problem-there is a problem some cars (like mine) develop with the grounding in the clockspring behind the steering wheel. It can affect any or all of the controls on the steering wheel-horn, cruise set buttons, and radio controls.
If some of those don't work, try them (without wrecking) with the steering wheel turned away to either side of the straight ahead position-if the stuff works then, you have this problem. There is a service bulletin on fixing it.
AlanW is offline   Reply With Quote
Old 08-06-2009, 06:09 PM   #4
fsttyms1's Avatar
Old 08-06-2009, 08:03 PM   #5
Registered Member
Thanks so much fsttyms1 (excellent avatar) and Alan! Heading to garage now. I'll post results.
Old 08-06-2009, 08:05 PM   #6
Registered Member
check the connector harness at the cruise control unit.
if the side engine mount or timing belt was done the cruise control unit needs to be moved out of the way. peek under the hood and make sure its plugged in.
mlassek is offline   Reply With Quote
Old 08-16-2009, 10:35 AM   #7
Registered Member
Thanks again folks. Radio and shift lite fixes went great. Still no cruise. I'm going to check the connector that mlassek recommended.
Also added a Blitzsafe interface so I could connect the iPhone. Got lucky on this one cuz there was an extra 14 pin slot in the back of the head unit! Still have full function of CD player!
Old 08-26-2009, 12:00 AM   #8
Registered Member
Well I solved the cruise control problem. The plastic retainer that accepts the cruise control cable into the throttle body linkage had broke. I did an ABS plastic repair and its good as new.
There was no way to buy that piece. I would have had to purchase the whole throttle body at about $500. So the cost of some Oakleys ABS plastic cement was just a bit more cost effective.
I snapped some pics but apparently I'm not yet worthy to post them.
This car turned out to be a good buy. Thanks to the help of this forum and a little more trouble shooting on my own, all the minor repairs were done for next to nothing and it runs great.
Thanks again.
Old 08-26-2009, 08:25 AM   #9
fsttyms1's Avatar
Thanks again.
on the fix
Oh and to post pictures, check out the link.
http://tl.acurazine.com/forums/showthread.php?t=573134
Old 08-31-2009, 03:41 PM   #10
Registered Member
I have the same problem with my cruise control. I dont know much about plastic repair. Could you give some details and/or post those pics when you can.
thx.
rockoutwuglockout is offline   Reply With Quote
Old 09-06-2009, 11:13 AM   #11
Registered Member
No problem. Here's a couple pics of the throttle body after I already started disassembling the linkage. The broke piece is still in place. It's a bit tricky getting it back together. All the conponents, washers, and spacers need to go back together in just the right order. When I first reassembled I had a washer flipped the wrong way (concave surface reversed). It went back together but the linkage was sticky. Very subtle thing to miss.
Here's some pics showing the problem and the repair:
To repair the piece, which is ABS plastic, I used standard ABS plastic cement (used for assembling ABS plumbing components) available at any hardware store. I cleaned the repair area with standard plastic pipe primer then taped a piece of flat non-ABS plastic to the side to form a dam to hold the cement. After a couple coats and 48 hours of drying, I carefully removed the form and excess cement.
Sure is nice to have cruise back.
Feel free to contact me if you need any help with it.
Old 09-06-2009, 11:16 AM   #12
Registered Member
And to thanks to fsttyms1 for the image posting procedure.
Old 09-08-2009, 07:12 PM   #13
Registered Member
eleventure's Avatar
Nice Z in the background!
eleventure is offline   Reply With Quote
Old 09-12-2009, 07:11 AM   #14
Registered Member
Nice catch. Its a 90 NA. Just replaced all the fuel injectors. Runs like new. I can't bring myself to part with it.
Old 09-16-2009, 05:04 PM   #15
Registered Member
abs plastic cement
Would I find this cement in the plumbing section?
Old 09-17-2009, 12:12 AM   #16
Registered Member
AdamType-S's Avatar
My tranny crapped out at 60k last spring when I was using the cruise control during a storm.. I never used it since lol
AdamType-S is offline   Reply With Quote
Old 09-17-2009, 08:55 AM   #17
fsttyms1's Avatar
Quote:
Probably not. Its just epoxy. Go to your local parts store or hardware store and ask for 2 part epoxys. (in Home Depot they are in the caulk isle
Old 09-17-2009, 08:55 AM   #18
fsttyms1's Avatar
Quote:
That wasnt the cause and shouldnt keep you from using it.
Old 09-17-2009, 01:54 PM   #19
Registered Member
AdamType-S's Avatar
Quote:
i know, its just the mental trauma..
Old 09-18-2009, 07:58 AM   #20
Registered Member
Yes. Just make sure its ABS cement. It will be black in color. Also, the stuff is pretty thick but to help it hold its shape more while setting up, you can let some air dry and thicken more before applying.
Also, do not use two part epoxy as recommended in the above post. It does not bond well to ABS plastic.
Old 02-28-2010, 05:22 PM   #21
Registered Member
Repair in place (no disassembly required)
Thanks for this great information! I also have the broken 'yoke' but did not want to disassemble the assembly. I got the ABS cleaner and cement, and also picked up a small piece of ABS pipe. From this pipe, I cut a "T" which I cemented in place to keep the cable from popping out. The following is a very crude picture of how this worked. The "C" represents the cable 'head', the "T" represents my custom cable stop, the "i" represent the cable wire and the "|" represent the left and right walls of the 'cable channel'. This view is from the top.
C
|T|
|i |
|i |
I was lucky in that my break was perpendicular to the direction of the cable channel, thus allowing me to use a "T". Obviously if the break is at a different angle, you could use a different shaped "T"
Once I had the "T" cut out and shaped, I put ABS cement in the area of the cable channel that the long side of the T would sit in, slid the T in place, and held it there using a pencil wedged between the engine and the T. I let it dry a bit, dabbed more cement onto the T, and did this several times. Eventually I removed the pencil and kept applying more cement.
I'm letting this dry as I type this but wanted to let others know about this.
(And, to ask the obvious...if this happens to so many people, why isn't this part available from Acura or other OEM parts suppliers?)
Terry851 is offline   Reply With Quote
Old 03-01-2010, 03:15 AM   #22
Registered Member
Well done Terry. I've had a few folks PM me on this fix. Getting it done w/o disassembly is definitely a plus. Can't drive an Acura w/o cruise. It just wouldn't be right.
Old 06-09-2010, 06:33 AM   #23
Captain Morgan ))
RusTL's Avatar
i dont have a functioning cruise control on my 03 TL-S either..after i hit the main swith the LED lights up on it, but when trying to SET it on the steering wheel - nothing happens (no indication on the dash either).
About to go start figuring this out...will keep you guys posted
RusTL is offline   Reply With Quote
Old 06-12-2010, 07:50 PM   #24
Captain Morgan ))
RusTL's Avatar
so, i have visually inspected some of the components, well, first of all the fuse is good, mechanical linkage is good too (including that plastic piece IllinoisREI mentioned), im thinking it has to be electrical, cuz ive seen some splices in the wiring which i Don't trust. Anybody knows where can i get electrical diagram for cruise control circuit?
Old 06-13-2010, 12:09 AM   #25
Registered Member
dudeinaTL is offline   Reply With Quote
Old 06-16-2010, 03:04 AM   #26
Captain Morgan ))
RusTL's Avatar
thanx dudeinaTL! pretty usefull info.. ill get right to it, hopefully ill get it to work
Old 06-16-2010, 03:41 PM   #27
Registered Member
I had the same problem as you RusTL and took it to my mechanic expecting a big problem. But he said it was just a loose connector so I was kicking myself for not checking it out first. So check those connections and you should be able to find something loose.
DaveG is offline   Reply With Quote
Old 06-16-2010, 07:55 PM   #28
Captain Morgan ))
RusTL's Avatar
Thanks DaveG, this definitely holds true, checking the connectors and stuff like that.
So i went in there today to inspect some wiring, and guess what! all the way up in there, stuffed above the cruise module i find VIPER alarm module!! (which i knew nothing about, since i am using the key to open the car).
The problem is, a lot of essential wiring is ran through the module, or been tapped into other wiring in the weirdest way possible. To top if off, all the wiring is cut in a barbaric kind of way.. so now got more stuff to figure out.
Old 07-07-2010, 01:07 PM   #29
Registered Member
My 2003 TL just broke the CC connection as well - but the cable got stuck behind the throttle blade control when i was merging on the highway. Not a fun experience. I have an appointment with my local dealer tomorrow for them to investigate it - but i am glad to hear others are experiencing this issue as well.
reilinjw is offline   Reply With Quote
Old 07-08-2010, 06:59 PM   #30
Registered Member
M T L T L's Avatar
i have this problem as well. I I fold the CC cable back n attached it to its self for now. It was causing my engine to rev high at idle upto 2 even 3K sometimes when the engine would get hot after some spirited driving. I would appreciate a detailed write up wit pics if u have for how fixing the CC linkage.
M T L T L is offline   Reply With Quote
Old 07-12-2010, 01:47 AM   #31
Captain Morgan ))
RusTL's Avatar
reilinjw- keep us posted on how it goes ok.
i got my nonfunctioning CC checked out- the weirdest thing, all electrical connections are good, i dont know whats wrong.. i was able to solve the CC problem on my other TL by throwing parts at it off of a donor car, but this time this isnt the case
also, got my VIPER alarm wiring figured out, but had a tough time programming a replacement remote. For those of you ever programming a VIPER 5901 remote: even if you follow the instuctions precisely you will FAIL because there is a certain time limit to program which manufacturer doesnt mention. what you wanna do is get your REMOTE ready first, and then follow the instructions quick, that way you have enough time to complete it.
Old 05-01-2011, 12:21 AM   #32
Registered Member
I just purchased a very nice used 2002 TL – S. The Cruise Control is not working. Looked through forums found lots of information. Here is what my problem description is:
Lower Left Dashboard Cruise Button pushed in, Light On.
Instrument Panel light does not come on. Special KUDOS to fsttyms1 and Trackrumer228 for their posts here, especially fsttyms1.
What I have discovered thanks to those people is:
The Instrument Panel light being on or off is determined (assuming a good light) by the cruise brake sensor being adjusted properly. I just went out and determined this by inspecting the brake sensor (seeing how it worked). I had tried fsttyms1’s recommendation of pulling up on the brake pedal but that had not worked; there was no play in my pedal at all. I noticed while inspecting the plunger switch that the plunger did not go ALL the way into its female host. (ALL THE WAY IN = NO BRAKES APPLIED) I taped together 3 pennies and then taped the pennies around the button that makes contact with the plunger; that made the plunger go all the way in. I took the car out for a drive and NOW the instrument panel light is ON but still no cruise.
I will need to inspect the cables tomorrow with a friend. The pics in IllinoisREI’s post are okay if you know what a GOOD one looks like. They’re helpful but only partially. I inspected my Throttle Body this AM and all I could tell was that there are two cables there and things move. I checked the Cruise Control Box (Near The windshield washer fluid) and did notice something interesting. Depending on how much I turned the mechanism to move the cable it did NOT always return to its home position, ALMOST LIKE THE CABLE ON THE OTHER END IS DISCONNECTED??? I will have to check that out in the AM.
jaystone is offline   Reply With Quote
Old 05-01-2011, 11:28 PM   #33
Registered Member
I am trying this type of fix tonight. I will let yoiu all know how it goes.
Old 09-17-2015, 07:02 PM   #34
New Member
abs is hard to find
The only ABS plastic I could find in my local Orange hardware store was a "P" trap. Turned out ok, since the contour is quite close to that of the broken yoke anyway. I do have 2 concerns tho-
1, the plastic is barely 3/32" thick
2, the only cement was the universal (pvc/cpvc/abs/dwv)
Should I put another "T" on to the reverse of the first for extra strength?
How long has this lasted for anyone else who's used it?
TheOnlyNate is offline   Reply With Quote
Old 09-17-2015, 09:13 PM   #35
fsttyms1's Avatar
Personally id walk out in your local salvage yard and pull the gear/cruise sprocket off a car there.
Old 09-17-2015, 09:40 PM   #36
New Member
[QUOTE=fsttyms1;15556742]Personally id walk out in your local salvage yard and pull the gear/cruise sprocket off a car there. [/QUOTE
I wish it was that simple... when I got the car (03 CL non-S) last month I searched every junkyard w/in 150miles. There is 1 CL among them and it has extensive front end damage.
Can I grab a throttle body from a similarly yeared/engined TL or anything else?
Old 09-18-2015, 07:37 PM   #37
Registered Member
^ Yes you can.
01 - 03 CL P or 00 - 03 TL P will work.
01acls is offline   Reply With Quote
Old 09-18-2015, 08:11 PM   #38
New Member
Thx much. I'll expand my search & hope for better luck.
Old 09-18-2015, 10:31 PM   #39
Registered Member
I was the OP and the repair is still holding fine now 6 years later. ABS DWV plumbing is more common out west but you should be able to find regular ABS glue at HD. It will be black in color. If I remember, I also ground off some shavings from an ABS fitting to add to the adhesive and thicken the mix for the repair.
Old 03-23-2016, 03:02 PM   #40
Registered Member
I'm trying to get the cruise working again on a '99 TL. I took the combo CC/TCS switch out, but not sure how to test, as I don't have a Helms manual for this car. (I have one for 99-04 Odyssey, which is decently helpful for under the hood stuff, but the switch they show is a simple Cruise switch). If anyone can provide a copy of the diagram for testing the combo switch, I'd much appreciate it.
Dave
soxfan62 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Feature Comparison- 15/16 TLX vs. 16 Accord blacktsxwagon Fifth Generation TLX (2015+) 42 10-27-2015 11:12 PM
Ignorant buyers not understanding VCM / complaining about transmission joflewbyu2 Fifth Generation TLX (2015+) 139 10-08-2015 12:16 PM
Upper Control Arm the same for 05 TL and 05 Accord? adreano17 3G TL Tires, Wheels & Suspension 2 09-29-2015 09:48 AM
Aerodynamic drag is a real drag Froid Second Generation RDX (2013+) 3 09-27-2015 07:16 PM
OEM system making static noise, limited Hz range, tweeter 4drviper 3G TL Audio, Bluetooth, Electronics & Navigation 0 09-23-2015 10:00 PM
Tags
1999, 2003, abs, acura, audio, cl, control, controls, cruise, horn, located, module, plastic, problem, problems, repair, tl, tsx, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
