Driver's side window stuck down, HELP!
Old 01-30-2011, 09:28 PM
7th Gear
matt24's Avatar
My 2002 TLType-S has had intermittent problems where the driver window will not come back up. Sometimes it would come back up after hitting the switch 2 or 4 times, but now it has gone thru about 3 times where it will not come up at all...but then the next day or later that afternoon it will just magically roll up when I hit the switch out of hope. There has never been any crunching sound or anything to make me think that the regulator or cables are hosed. Of course it's stuck down now, so I finally took the driver's door panel off, and I can hear the big relay clicking up in the front upper part of the door when I hit the switch up or down. This clicks only when I try the drivers window...no clicking for any of the other windows. The relay has the numbers 72256-S0K-A010 and has Honda ABS (OMRON) printed on the outside.
Does this relay have something to do with my drivers window not coming back up?
I've read about the reset, and that did not work either. Thought I'd ask you guys first.
Any help would be great, Thanks! Matt
jblessing
08-08-2018 09:43 PM
acura_dipset_tl
01-01-2016 03:02 PM
sockr1
10-01-2015 01:31 AM
PortlandRL
09-14-2015 12:01 PM
ahsm
09-09-2015 08:35 AM
Quick Reply: Driver's side window stuck down, HELP!
