Need part number for 03tls recall
Old 07-26-2011, 08:38 PM
Max Boost's Avatar
AFTER 6 YEARS MY BABY GAVE UP, THE TRANSMISSION IS A DONE DEAL, SO I CALLED 2 DEALERS AND I'LL I GET IS THE RUN AROUND, DOES ANY ONE HAVE THE PART NUMBER FOR THE RECALL PART AND IF POSSIBLE PICS OF THE PART, IF SO THANKS FOR THE HELP PEOPLE.
Old 07-27-2011, 02:24 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
whats yur current mileage?
what are you looking for?
the trans recall issued in 2004 was to install an `external oil jet kit` into the normal atf filler hole - to directly lube 2nd gear shaft and gear
has nothing to do with normal clutch pack wearout, which early wearout is covered by the extended warranty
If your recall was never done and there is certain heat damage found inside with a boroscope exam- you may still get a replacement trans as warranty,
are you part of covered vins for the 7.9/109 trans warranty?
Old 07-27-2011, 10:26 PM
totaledTL's Avatar
Part number-?
Old 07-28-2011, 12:58 AM
01tl4tl's Avatar
I can only guess he wants the oil jet kit? thats not going to fix the trans
chalk it up to the great misunderstanding of recall, replaced under warranty at recall, and extended warranty
hey my post 05 didnt get a jet kit!! doh Its located inside the trans now!!
NitroViper
03-20-2017 09:50 PM
hand123
09-10-2015 09:29 AM
hand123
09-10-2015 09:27 AM
Quick Reply: Need part number for 03tls recall
