Help diagnose pulling symptoms
Old 11-26-2014, 01:12 PM
CL-S6SPEED's Avatar
My car is pulling hard left on acceleration at any speed and starts swerving right when I let off. I can steer the car with the gas pedal basically. Alignment is in check. Any ideas?
Old 11-26-2014, 05:57 PM
3.2TLc's Avatar
Tires, rims, loose suspension or steering component ? Maybe a bad rack ?
Old 11-27-2014, 09:59 AM
Mr.Helpful Diagram
ErickUa5's Avatar
Try switching the front left tire to the right side and see if it pulls in the opposite direction, If it does its your tires.
Also tire pressures make sure they are equal, If not equal it can cause pulling.
If none that worked and you checked what 3.2tlc mentioned then its simply a bad alignment, I would take it back to them.
Old 12-15-2014, 08:35 AM
CL-S6SPEED's Avatar
Turned out to be a radial tire pull guys
The following 2 users liked this post by CL-S6SPEED:
3.2TLc (12-15-2014), ErickUa5 (12-15-2014)
Old 12-15-2014, 11:34 AM
MarcDavidoff's Avatar
Thanks for the update. Was it driving normal and quietly just cruising? Just pulling hard left on hard acceleration?
SidhuSaaB
05-30-2020 12:40 AM
08KBP_VA
10-22-2019 01:55 PM
MilanoRedDashR
10-08-2015 10:30 AM
us285126
10-02-2015 02:03 PM
thegipper
09-28-2015 01:01 PM
Quick Reply: Help diagnose pulling symptoms
