Gear indicator
Gear indicator
Occasionally while driving in D5 the indicator on the dash will go blank then when I wiggle the shift lever the light will come back on. This happens with nuetral as well. I can hear a solenoid clicking when "wiggling" the shifter.
Is my shift cable worn or is there a switch in the center console that is worn?
May need to pull the center console cover and investigate the situation a bit closer. Perhaps a loose connector or something sticking ?
Turns out it was the transmission range switch that had fallen out of adjustment. Loosen 2 bolts and rotate the housing slightly. Very easy fix.
01tl4tl (01-14-2015)
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
guyvelella
09-30-2015 11:02 PM
AcuraKidd
09-26-2015 04:10 PM
