Radiator gauge
Old 02-15-2011, 07:20 PM
8th Gear
E's00TL's Avatar
Radiator gauge
Hey Guys,
my radiator gauge is fluctuating. it got real close to "hot" today and i am worried. should i put coolant in?
thanks
E
Old 02-15-2011, 09:46 PM
totaledTL's Avatar
Did you check the coolant level? Check w/ engine COLD- to radiator neck, also check the resv. The proper level is marked on it. Check that the hose inside is connected.
Any visible leakage under the car, in engine bay, etc.? How does the oil look? Do not drive it until you find out what the problem is. Overheating can cause serious (read- expensive $$) damage.
Old 02-16-2011, 02:50 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
all of the above!!
the TL never runs past half unless a serious problem- being bad water pump, bad fan sensor not turning on, stuck thermostat etc
CL-S progression 01
01-26-2016 04:15 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
2Quik
09-21-2015 08:51 AM
Quick Reply: Radiator gauge
