How to replace the tail light bulb
Old 04-28-2012, 03:49 PM
eespinos93's Avatar
Hi guys. So I have a 2003 Acura TL Type-S and one of my brake lights is out. I just need to replace the bulb not the entire housing itself. So it would be helpful if I could get instructions on how to remove the rear bumper and maybe open the housing to replace the bulb. Thanks.
Old 04-28-2012, 08:22 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
please register with www.owners.acura.com need cars VIN
free download of owner book for your year- has this job in it
also look in our diy section https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
ours are changed from inside the trunk
replace bulbs in pairs (ours are sold that way),,and brake lights= do all 4-
they get the same use!
welcome to the forum!
Old 04-28-2012, 08:30 PM
deal with it
dreem1er's Avatar
pop the trunk unscrew the black round thing that are used to hold the cargo net, you have have to remove the plastic in the center, just pull it up clips pop right out, pull back the carpet and you have access to the lights
Old 04-29-2012, 12:19 AM
2G TLX-S
Edward'TLS's Avatar
Received 1,133 Likes on 813 Posts
No need to remove the bumper. The brake-light bulbs can be easily changed from inside the trunk.
Old 04-29-2012, 10:34 AM
01tl4tl's Avatar
those are 1/4 turn screws on the plastic bit on bottem edge as you open trunk,
then lift the piece out
the carpeted corners right in front of the bulbs are cardboard,,pull it forward and down to gain access to bulbs
dont try to remove anything--just get enough room for your hand
the bulbs are in with 1/4 turn too
as said above- the big round nut that holds the cargo net to sides of trunk,,those get removed so piece can be moved
Old 04-29-2012, 08:40 PM
deal with it
dreem1er's Avatar
i remember having those...i've had to changed clips so often i barely recall which are oem which are random and which are homemade
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
Ny1718
09-11-2015 09:21 AM
brjones9
09-03-2015 07:30 PM
Quick Reply: How to replace the tail light bulb
