Cel flashing and tcs light code p1740?? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 06-04-2011, 08:58 PM   #1
New Member
Cel flashing and tcs light on car is shaking badly and code coming up is p1740. Anyone know what that means? It's an Acura TL, 2000.
Kayla is offline   Reply With Quote
Old 06-04-2011, 09:41 PM   #2
Registered Member
without looking up the code--which you can do on google easily
its probably multi cylinder misfire--which a shop will tell you means replace all the ignition coils
but we will tell you the truth about it needing just 1, 50 dollar coil,,easy DIY
How many miles on the car,,
replaced the spark plugs yet with the correct ngk 8 dollar each ones?
01tl4tl is offline   Reply With Quote
Old 06-04-2011, 09:45 PM   #3
Always Working In
I had that code come up with a bad coil. That code is a transmission code. The misfire codes are in the p0300 range.
my.daily'tl' is offline   Reply With Quote
Old 06-04-2011, 09:48 PM   #4
Always Working In
Same thing. Cel fladhing and tcs light on. Ran pretty bad at idle and accelerating.
Old 06-04-2011, 10:34 PM   #5
Registered Member
piggylover1985's Avatar
Sounds like the torque converter circuit is having problem.
piggylover1985 is offline   Reply With Quote
Old 06-05-2011, 01:21 AM   #6
Registered Member
well, you are the trans guru- so I bow to your knowledge
Suggest they proceed to a trans shop for another opinion
it could be either at this point
we need mileage and maitenance history to eliminate things
example recent spark plugs of wrong type, and coil was damaged internally during the job,,2 problems which can fake the computor out
codes are clues--not diagnosis in themself!!
Old 06-05-2011, 08:16 AM   #7
Registered Member
Hi there 01tl4tl, how are you doing lately ? Visit a tranny shop for an EDS, cost round 40 bucks and they will let you know if the problem can be fix externally or not.
Old 06-05-2011, 08:34 AM   #8
Registered Member
How bad is the fluid ? Does it look or smell burnt ?
Old 06-05-2011, 10:51 AM   #9
Registered Member
want to explain an EDS to us please?
How am I? see my hidextra light issue!!
Old 06-05-2011, 05:01 PM   #10
New Member
theres 150k miles on it and the spark plugs were changed last year or so..it shakes as soon as i turn the car on and continues as i drive...also im dumb when it comes to cars so please dont use big words that i wont understand lol..transmission was replaced about 4 years ago from the acura dealer due to a recall..
Old 06-05-2011, 05:43 PM   #11
Registered Member
Do you feel power loss ? Like lockup is stuck on ? EDS External Diagnostic Service, so they can tell if the car can be fix externally or they will have to do an internal service in that case the tranny will have to be open up.
Old 06-06-2011, 01:07 PM   #12
2000 Acura TL
closetprisoner's Avatar
You should try to replace the 4th gear oil pressure switch, switch cost about $60 and save on labor and install it yourself, just did mine over the weekend. My car shudder, shake a little at about 20-30 mph, below or beyond that speed it perfectly fine but i change the switch anyway.
closetprisoner is offline   Reply With Quote
Old 06-06-2011, 10:16 PM   #13
Registered Member
the poster said not a car person, diy not likely
so a trip to the transmission shop for inspection should tell what it really needs
could be ignition coils, or if the wrong spark plugs were used- that will cause frustration
after several months
Can you tell us what spark plugs went in--were they about 8 dollars each?
and the trans- maybe not replaced under recall- different issues-recall/failure with heat damage, and court ordered extended warranty for clutch wearout
does the trans have blue paint on the bolt heads???- open the hood and look down at
small things bolted on the trans-- will have blue and the bigger bolts that go thru the trans also blue on the head--very easy to spot
those mean it really is a replacement trans from acura
Old 06-06-2011, 11:11 PM   #14
Registered Member
niju321's Avatar
if you are in park, and hit the gas....does the shaking get a lot worse? if so sounds like coil issue, especially given recent spark plug change. those coils are fragile, one little bump and they may fail months later
niju321 is offline   Reply With Quote
Old 06-26-2011, 09:17 AM   #15
Registered Member
Hey Kayla, I had the same problem with my 99 Tl shake when start and while driving cel blinking and tcs light comes on. First I replace spark plugs car ran good for 1 day then same problems again so I started running all kind of test on the car till I finally decided to disconnect each coil and see if the engine was misfiring. Come to find out coil number 6 was bad. Long story short after spending $200 bucks on my car all it took was a $50 coil to fix my problem. Don't know if you fixed it already but to find out which coil is bad. Remove the plastic cover on the engine and you'll see the coils (3 black boxes with a wire connected to it) disconnect the first one if the engine shakes then it's good. Connect it back in and do the same thing to the second one. After the third one on the back of the engine there is three more do the same till you find the one that doesn't not shake the engine when disconnected that is the bad one. Replace it and you should be back to 100%. Now for you transmission heads out there can a solenoid stop working only when it's hot and start working again when cold?
Knight hawk Acura is offline   Reply With Quote
The Following User Says Thank You to Knight hawk Acura For This Useful Post:
01tl4tl (06-26-2011)
Old 06-26-2011, 12:01 PM   #16
Registered Member
do you mean trans operating temp,, or outside air hot or cold?
Old 06-26-2011, 02:21 PM   #17
Registered Member
Trans operating temp
Old 03-09-2012, 03:19 PM   #18
New Member
hey guy, I'm having the same issue my check engine light is flashing every so often and the tcs light is on. I read peoples post trying to come up with a solution, but haven't found one yet. Anyways I have 220,000 miles on the car. I started by replacing the egr valve since it threw a random misfire code. I changed the all 6 spark plugs with the NGK laser double platnum and one coil pack and the car ran better, no more shaking on idle accelerates better. I reseted the car and drove the car, everything seems fine for a couple of day then the cel came3back on and started flashing and the tcs light came on again. Any help would be great.
leftylucky615 is offline   Reply With Quote
Old 03-09-2012, 05:51 PM   #19
Registered Member
I have the same problem. The car will not restart when hot, without this happening. Usually accompanied by the shiftlock clicking. I am about to go replace the ignition switch. If that does not help, I will try tune up and Coil packs. (203k 1999)
95CivicNOWa99TL is offline   Reply With Quote
Old 03-09-2012, 05:58 PM   #20
Skirmich's Avatar
That code is Closely related to a Suicide Tranny... Just before my tranny was Done I got that Exact code + Check Engine: 2 days later my tranny was toasted.
In my Understanding once the Clutch pack starts to slip it realeases alot of Debris that Clogs the TQ Converter Solenoid first but thats IMO.
Skirmich is offline   Reply With Quote
Old 03-09-2012, 06:37 PM   #21
Registered Member
Replaced, I will advise if this fixes my issue in the next couple days.
Old 03-12-2012, 12:44 PM   #22
Registered Member
Ignititon switch replaced, engine is still stalling out (TCS, ABS, CEL light, etc, etc...). I will clean the EGR port this week, and advise if this fixes it.
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 3G TL Problems & Fixes 50 01-19-2017 02:13 PM
Have you had many people flash their headlights at you? RLX-Sport Hybrid Third Generation RLX (2013+) 43 12-16-2015 11:45 PM
Cleaned solenoids, now D4 flashing error ibGTV First Generation CL Discussion (1997-1999) 14 09-28-2015 04:40 AM
Over heating blues Bahamanurse1 Second Generation TL (1999-2003) 17 09-10-2015 11:05 PM
Tranny only 2 years old, pressure switches already bad??? HeloDown 3G TL Problems & Fixes 4 09-08-2015 07:51 PM
Tags
1999, 2000, 96, acceleration, acura, cel, code, honda, light, mdx, means, p1740, tcs, tl, trans, transaxle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
