Aiming Lowbeam / Drl problem, help please.
Old 03-10-2012, 08:15 PM
Malyuht's Avatar
I recently installed depo headlights and aimed them.
I aim the low beam and got them to lineup, but when I turn on drl/high beam.. left side is higher then right side. (sitting in car looking straight forward).
So I raise the right side so it line up with left side...but when I turn on lowbeam, left side is lower then right side.
Sorry for my english but anyone have fix for this?..
Old 03-11-2012, 12:32 AM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Left low Beam is Aimed Lower than Right to fight Glare...
Use your High Beams as Reference those should Aim even then Left side Low Beam would aim a little bit lower than Right not the Other way Around.
Low Beam = Lower than Right
High Beams = Even, The reflective housing should output kinda an "A" figure when facing a wall.
01tl4tl (03-11-2012)
Old 03-11-2012, 04:45 AM
Malyuht's Avatar
So dont use lowbeam as reference? Is that for every car or just 2g tl? and whats a good height to aim the highbeam? Thanks.
Old 03-11-2012, 09:48 AM
Original Owner / Oct 1998
Carbuff's Avatar
It's possible that you have one of the new lowbeam bulbs in the wrong "spot" . There are little bumps in the socket that are supposed to line up to notches in the bulb flange.
If you "miss" (not that difficult to do) the bulb will be crooked...and adjusting that headlamp would cause the highbeam aim to be incorrect.
Just a thought.
Old 03-11-2012, 11:10 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
our diy section has the aiming guidlines,,
a certain distance from wall = height of center part of beam
driver side beam is set low and in, so you dont blind oncoming traffic
they fixate on the light,
where the eye goes the hands follow,,and the car turns..
right into you!
Pass side set long and slightly to the right, so you can see road edge lines and pedestrians farther ahead
Old 03-11-2012, 04:14 PM
Malyuht's Avatar
Carbuff - yes i took both headlights out and put both lowbeam into the socket exactly the same way, so that isnt the problem.
01tl4tl - oh i see, that explain why my lowbeam line up the way they did.
As always, you guys are great help. Thank You!
Old 03-11-2012, 05:51 PM
Skirmich's Avatar
Yup pretty much if you use it as Reference make sure the Drivers Side is lower than the Passenger.
I think most newer cars use that kind of setup, Even Projectors output (The Steps) start to go up to the passenger side when properly Aimed.
Ex:
Notice how Drivers side is aimed lower than the Passenger, This is not Necessary for High Beams since there´s No way to Stop Glare with those.
This is True even for our Reflective housings.
Hope that Clears things Out for You.
Old 03-12-2012, 11:35 AM
01tl4tl's Avatar
you should be on low beams when oncoming traffic approaches~
so glare and aim not as big an issue on high beams
Old 03-12-2012, 12:20 PM
Malyuht's Avatar
Skirmich - thanks for the pic, thats exactly how my low beam look like and i thought it needed aiming lol..but i got it all work out now.
Thanks guys!
SidhuSaaB
05-30-2020 12:40 AM
12vancover
10-16-2015 12:04 PM
Matthew Purpura
09-25-2015 06:10 PM
4drviper
09-23-2015 09:00 PM
2Quik
09-23-2015 01:03 PM
Quick Reply: Aiming Lowbeam / Drl problem, help please.
