Car Revs Up And Down on its own - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 02-04-2010, 07:43 PM   #1
Registered Member
My 02 TL sat for about 4-5 months. I probably started like 3-4 times during that time. The last time I started it it ran fine for about 3 minutes than just started revving up and down. It revs down till it sounds like its about to stall and than shoots up. Up and down up and down. Even when Im driving if I just coast it does it.Im not sure what it should normally idle at but when im sitting at a red light I can feel more pressure on the brake pedal like the idle is running way to high, its at 1100rpms. I took out the IACV and cleaned it, still does the same thing.... Any Ideas?
whistlekleen is offline   Reply With Quote
Old 02-04-2010, 08:15 PM   #2
Thread Police Chief
adamlee05's Avatar
Could be the MAP sensor, its located on the rear intake plenum.
adamlee05 is offline   Reply With Quote
Old 02-05-2010, 09:55 AM   #3
fsttyms1's Avatar
Quote:
Doubtful,
Its probably still the Idle Air Control Valve, or a vacuum leak. If the idle is reving up and down or high its usually one of those. It may also be a TPS sensor
fsttyms1 is offline   Reply With Quote
Old 02-05-2010, 11:58 AM   #4
Registered Member
I vote for the TPS
rcb2000 is offline   Reply With Quote
Old 02-05-2010, 12:05 PM   #5
fsttyms1's Avatar
Quote:
Originally Posted by rcb2000 View Post
I vote for the TPS
But that doesnt typically cause the rpms to fluctuate though. That is usually the IACV.
Old 02-05-2010, 01:34 PM   #6
Registered Member
Yes the IACV is usually the issue but given he's cleaned that and it had no effect, guess I would get the multimeter out and verify the correct input voltage and that it is functioning correctly, but seems like there is too much of a swing in rpm for it to be the IACV. Can't you use a resistor to test it's functinality and rule it out or verify it's bad?
Old 02-06-2010, 01:45 PM   #7
Registered Member
nisreo's Avatar
Take your intake tube off, start the car. On the inside of the throttle body on the bottom, there is a hole. Cover about 3/4 of that hole with your finger and see if the idle smooths out. If it does, its a good sign you have a bad IAC.
nisreo is offline   Reply With Quote
Old 02-07-2010, 01:40 AM   #8
fsttyms1's Avatar
Just because he cleaned it doesnt mean that its working correctly. First thing i would do is take some carb cleaner (in a spray can) and with the motor running is spray around the intake plumbing to see if there is a vacuum leak. If there is the idle will change.
Also there isnt too much of a swing for it to be the IACV, it can swing as much as a few thousand RPM.
Old 02-07-2010, 01:48 AM   #9
Registered Member
AcuraTL99's Avatar
Or a bad IACV, that happened to me last year.
Mechanic checked, cleaned, nothing, had to replace the whole IACV.
AcuraTL99 is offline   Reply With Quote
Old 02-11-2010, 08:42 PM   #10
Registered Member
Hi Guys :
I swear this has happened to me twice and BOTH times it was bad gas ! This seems to happen when I drove up north and filled up in rural areas. I think it was water in the fuel and I resolved it by topping up the tank up with new/different gas.
It doesn't hurt to try it ?
smartypants
smartypants is offline   Reply With Quote
Old 02-17-2010, 11:26 PM   #11
Registered Member
Thanks for the advice guys, I had the same problem yesterday and I cleaned the IACV and voila, problem solved.
daquel is offline   Reply With Quote
Old 02-18-2010, 07:41 PM   #12
Registered Member
nsnrider's Avatar
definitely the IACV, how did you clean it, just spray cleaner in the throttle body or did you actually unbolt the IACV, sprayed the cleaner in the unit itself and verified that the shaft is turning? You might need to clean it again.
Hondas are notorious for having IACV valve stick after the engine sat for any extended period of time.
nsnrider is offline   Reply With Quote
Old 03-09-2010, 11:03 PM   #13
you know me...
unINSPIREd's Avatar
this thread saved me so much trouble.
unINSPIREd is offline   Reply With Quote
Old 03-10-2010, 10:20 PM   #14
Registered Member
It is your IACV valve, I had a same problem, Acura replaced mine under warranty and no more idle issues.
03TLS4me is offline   Reply With Quote
Old 03-13-2010, 12:31 AM   #15
you know me...
unINSPIREd's Avatar
Question
I went through the process of cleaning and reinstalling the IACV and it did not work. Theres a plastic screw on the IACV and I read somewhere that this screw is to tune the idle. Does anyone know if this is true?
Old 03-13-2010, 11:27 AM   #16
fsttyms1's Avatar
I havent seen a plastic adjustment screw on the IACV. Dont know where you read that. If you cleaned it and it still doesnt work, its likely you need to replace it.
Old 03-13-2010, 01:07 PM   #17
Registered Member
It was the IACV. I cleaned it once by just taking it off and spraying it down with throttle bottle cleaner and wiping it down and that didnt fix it. So I decided to take it off again and clean it good with Qtips and throttle bottle cleaner. Spent a good 20 minutes cleaning it good and that fixed the problem. I appreciate everyones advice.
Old 03-13-2010, 10:12 PM   #18
you know me...
unINSPIREd's Avatar
Unhappy
I think its the TPS that lets you adjust the idle. I replaced the whole IACV and even ran sea foam thru the vacuum lines and fuel tank and the issue didnt go away. Throttle body was cleaned as well.
Thread Thread Starter Forum Replies Last Post
Share your best MPG and how you achieved it. peti1212 Acura ILX Discussion 14 09-24-2015 01:22 PM
2000 Acura TL 3.2 Reverse (Only) Slips Under Load Mike Bertram Second Generation TL (1999-2003) 9 09-10-2015 10:27 AM
Electrical issues? Phambam12 3G TL Problems & Fixes 4 09-06-2015 07:57 PM
Peugeot: Fractal Concept News Yumcha Automotive News 3 09-06-2015 05:40 PM
Battery might be dead or not. jordanboi Second Generation TSX Discussion (2009-2014) 16 09-05-2015 02:33 AM
Tags
02, 2002, 2003, acura, car, down, idle, idling, mdx, own, reving, revs, revving, tl, tsx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
