Belt squeal when cold
Idk if this happens to you guys but lately I've been noticing on cool damp days roughly around 0c to 10c there's a belt squeal after first starting the engine that only lasts for a few seconds and goes away.
I replaced the drive belt when I first noticed the issue then a year later I noticed it happening again so I had it replaced under warranty and this year now that spring is starting it's been happening yet again. But only on cool damp mornings.
Idk if it's because I'm using goodyear gator back belts or if maybe my tensioner is worn but it's still giving proper tension. One of my friends also said it was common for early J series engines that were in the TL's and Odyssey's so I'm wondering if that's true too.
Not even a couple of years old only put 25k on it since I had all the belts replaced when timing belt was done. It's a weird intermittent problem because it didn't happen today since it was fairly warm and dry this morning.
was the tensioner replaced when you replaced the belt?
But also, are you sure the tension on the PS belt is good? It should deflect about 1/3 to 1/2" when pushed with two fingers.
OK, wasn't sure since it sounded like you mentioned changing one belt. Have you watched the belt in operation while the engine is running? My tensioner went bad last year and you could visibly see it vibrating when you rev the engine up, a mechanics stethoscope also showed it making noise. Still, my belt didn't squeal but if you've never changed your tensioner there is a good chance it's weak or going bad with the age of the car.
You can tell if the bearing is bad by turning it by hand
Tension on the belt is good it's just only squeaking when first starting the car if it's wet outside like after a rainstorm or a humid day. I'm just wondering if maybe the bearing on the tensioner wheel is going bad or if it's just that I'm using a good year gator back belt. If it gets worse I might just replace both the tensioner and the belt.
