AC/Heater blower stopped working
Old 07-22-2016, 01:56 PM
Edwin Gomez's Avatar
The plug for the blower was replaced because the old one had broken but the blower is still not working , with the broken plug I could move the cable and it would start up again any idea as to why it's not working now with the new plug ?
Old 07-24-2016, 11:58 AM
02tl-p's Avatar
there could be a short somewhere in the harness. Have you tried wiggling the new plug around to see if it will function?
Old 07-24-2016, 07:41 PM
jra8858's Avatar
By plug, I'm assuming you mean the wiring connector? Did you disconnect the battery before replacing it? If not possibly you could've blown a fuse so I would start there and look for a blown fuse. Also double check to make sure you wired the connector properly(positive to positive, negative to negative etc)
dubz ASPEC
05-15-2023 02:06 PM
RobbDizzle
12-01-2017 01:32 PM
Kwizzle
2G CL Problems & Fixes
07-06-2016 09:49 PM
z643167z
2G TSX Problems & Fixes
06-28-2016 01:55 PM
sidefx00
Integra
02-16-2016 07:21 PM
Quick Reply: AC/Heater blower stopped working
