99 TL Won't Start
Old 02-13-2011, 02:45 PM
Jhaas07's Avatar
99 TL Won't Start
Car has been running fine until yesterday morning. I went outside to head to the store and nothing but a click. Have full power to everything ( windows, lights, radio etc...) Checked my battery power which is fine. Tried to jump it as well and didn't work. I turn the key and you here the click click click but nothing.
I replaced the starter about 20k miles ago in late '08.
I'm not much of a mechanic but was wondering if any easy things I could check that would save me a lot of money before I have it towed tomorrow. I've been searching the forums for 30 minutes and the one thing I saw that I could try had to do with cleaning the terminals to make sure no corrosion has built up.
Outside of that any other things I might be able to check or am I basically screwed>?
Old 02-13-2011, 04:26 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Battery would still be the first thing to check, then i would check the starter.
Old 02-13-2011, 05:48 PM
Jhaas07's Avatar
It had 12.4 on the little battery meter for what that's worth. I think that is a tad low but I'm not certain.
Old 02-13-2011, 05:59 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
a 99--I go with ck the ignition switch back-electrical part
Acura replaces once under recall then on you the next 3 times it fails
try wiggling the keys slightly,, and remove any excess keys from ring
Will it shift to N when off?, then try starting- with brake and park brakes on
Old 02-13-2011, 06:10 PM
Jhaas07's Avatar
Okay, as far as the ignition switch is that something I could replace myself as a novice? I imagine it'll take a couple weeks to get that from Acura.
It will allow me to shift it to Neutral but it wouldn't start.
Old 02-13-2011, 06:26 PM
soria's Avatar
Yes, its doable. You can find instructions in the DIY section of the forum.
Old 02-13-2011, 07:42 PM
1999 Acura TL
leo99's Avatar
try the saftey override
Old 02-13-2011, 07:57 PM
Jhaas07's Avatar
What is this?
Old 02-14-2011, 12:09 AM
01tl4tl's Avatar
he can get it to N so thats not an issue
IF it wont shift out of Park- lift that small cover on right side of shifter plate,
insert car key- no kidding- and push straight down-
it releases the lock and you shift to N, then car will start
This safety device is to warn of no or partial brake light operation and can also fail on its own
the ignition key part is a simple diy for the limber~
call `acura care` and see if it was ever done under recall
1 800 382 2238 x5 gets a human- have cars VIN in hand
parts store may have in stock or next day less than 50 dollars,, acura- special order
Old 02-14-2011, 12:18 AM
Jhaas07's Avatar
Is this what I'm looking for?
Jhaas07's Avatar
http://www.autozone.com/autozone/par...er=223242_0_0_
Old 02-14-2011, 05:40 AM
1999 Acura TL
leo99's Avatar
Originally Posted by Jhaas07
What is this?
This same issue has happen to me before. don't waste your money. there is a little slot next to your shifter. take off the cover and stick you key in it.... i forgot the process but it is something like that. look it up in the owner manual.
Old 02-14-2011, 05:42 AM
1999 Acura TL
leo99's Avatar
yes.... I changed the ignition switch back before too. just try the key thing first man...
Old 02-14-2011, 11:06 AM
01tl4tl's Avatar
leo-
I descibed the nuetral safety switch override a few post above.
this is if it wont shift out of park
make sure brakes and park brake are ON
remove small cover on right side of shifter- insert car key- push down to unlock and shift to N
remove key and use to start car
Will have to repeat this each time you turn the car off
Old 02-14-2011, 12:18 PM
totaledTL's Avatar
Take battery off, have charged first then load tested. 12.4v sounds low. Check both batt. cables (both ends) to verify they are clean & tight. Have radio & nav. codes available.
Check easy stuff first. Connections are weak points.
Old 02-14-2011, 12:56 PM
rcb2000's Avatar
go buy a new battery and fix the problem the easy way by replacing the dead battery, and next time you jump a car don't hook both jumper cables to the battery on the dead car you hook the positive to the battery but the negitive goes to the engine block not the neg post of the battery.
Old 02-15-2011, 01:29 PM
Jhaas07's Avatar
Yeah, I finally had to take it in to shop. It was the starter.
$240 for part and $100 for labor.
Old 02-15-2011, 07:53 PM
1999 Acura TL
leo99's Avatar
did you try the override first?
Old 02-15-2011, 09:31 PM
totaledTL's Avatar
And you replaced it in 2008? Have receipt? Warranty period?
Old 02-16-2011, 02:40 PM
Jhaas07's Avatar
It was a one year warranty on the starter.
Jhaas07's Avatar
Yeah, the override was fine btw I did check that.
Old 02-17-2011, 09:14 PM
falconsman's Avatar
Wow, that's pricey, do you have an advance auto parts in houston, the starter should only be 125 bucks and it easy to install, two bolts and a couple wires. a lil late for that news now but I have the same issue as well.
02-25-2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
obert
12-14-2015 11:36 PM
whitesoxsfan12
09-13-2015 02:09 PM
ninersfgiantsfan
09-09-2015 01:14 PM
Quick Reply: 99 TL Won't Start
