grinding noise from rear brake
Old 05-31-2011, 02:34 PM
dc2kid's Avatar
hey does anyone know what the problem could be everytime i brake the passenger side rear brake makes a grinding/rubbing noise the brakes were relaced 4 months ago lots of pad left could it be the caliper?
Old 05-31-2011, 02:42 PM
CTS-V Import Slayer
MichaelBenz's Avatar
You can visually see both sides of the rotor and that there is plenty of pad left, because that would be my first thought was pad worn out. That can happen fast if you dont reset the caliper correctly or fully when changing out the pads...or if it is just a lazy caliper that needs replaced that you missed prior.
But if you can clearly see pad on both sides of rotor and no scoring on either side of rotor - something in the wheel bearings would be my next train of thought. Worst case scenario would be CV joints, but that would depend on the grind and when it was happening. CV's usually start grinding most when turning when they start to go out....which usually would be something you would have noticed before now.
Just some thoughts....
Old 05-31-2011, 03:55 PM
dc2kid's Avatar
this the noise only comes when i press the brakes
Old 05-31-2011, 04:45 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
ck for the 3rd tab prob on the inner pads
supposed to be a raised tab on each end,,one holds the noise maker arm for low pad warning
the other is empty
IF there is a 3rd tab in the top center- its hitting the caliper piston -causing pad to run crooked
easy ck= get on ground to look at inner side of rotor
If it has half its width shiny and half rusty looking- not being used looking
you have the extra tab!!
several makers use the RL backing plate and sell it as a TL pad but its not
You can grind off the extra tab or swap out the correct pads
Will cause all sorts of noise- weak braking etc until fixed
Old 05-31-2011, 04:47 PM
01tl4tl's Avatar
did you clean and lube the slider parts where the pads move in and out?
flushed brake fluid in last 2 years?
Old 05-31-2011, 04:49 PM
greddycl-s01's Avatar
when my Eclipse turbo had this problem it was the pad had worn out and the caliper was scratching the rotor
Old 06-01-2011, 10:13 AM
totaledTL's Avatar
If just one pad worn, suspect caliper (sticking piston, slider pins dragging) esp. if you never replaced the brake fluid. Also chk. for improperly installed pads, lack of lube on sliding parts.
Who last worked on them? Brakeway, Midas, or other get it out door quick place?
Old 06-01-2011, 11:11 AM
rcb2000's Avatar
if you did not turn the rotors or replace them then I would expect it to make a grinding noise as there usually is a lip on the rotor that is all rust and drags against the new pads when the brakes are applied most of the time it's not an issue but occasionally it is due to the fact not all pad sizes are the same some are smaller than others and if you installed one that is slightly larger than the old ones then you have this issue. look for the lip on the inside diameter and outside diameter relative to the pads id and od.
jliu6789
09-08-2015 08:02 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
nishant11
09-02-2015 10:34 AM
Quick Reply: grinding noise from rear brake
