2000 TL Stalling / stuttering when cold
My newly acquired TL with almost 150M is exhibiting stalling/stuttering issues when driving the first few blocks in the AM. Seems to want to cut out like a bad fuel delivery or intermittent spark issue. Was having some trans shifting issue I am also looking into, but this seems more computer or spark related. Just stutters like it is going to stall. If I gas it, feather the pedal it (I want to believe it) prevents stalling, but it does feel like it has a mind of its own--like a sensor issue.
Seems to go away after warm.
Any ideas?
Any ideas?
Have you cleaned your throttle body or idle air control valve
Hey, thanks for the quick reply!. No I have not but that sounds totally logical. Just getting to know this car. Hopefully that is easy to get to. Would running a can of seafoam do any good at this point?
Eurotrash
Check the second link below for the strange symptoms you can get when the Main Relay acts up.
Everything there is to know about your Honda/Acura main relay:
How the Main Relay works
When the Main Relay goes bad
