I know my air intake hose is broken but...
Old 05-19-2015, 01:01 PM
6th Gear
rdrgzbrandon's Avatar
I need help identifying what this hose is called and if i need to replace it along with the air intake?
Don't know much about cars but if its broken than it must not be good.
I appreciate the help.
Old 05-19-2015, 01:03 PM
Received 8,613 Likes on 6,652 Posts
go to the junkyard/pick a part and go grab it. I wouldn't buy NEW per se..
or a good time for a cold air intake?
Old 05-19-2015, 01:04 PM
Received 16,260 Likes on 11,971 Posts
looks like a shark bit it.
Old 05-19-2015, 01:34 PM
6th Gear
So replace both?
I thought about the cold air intake.
Old 05-19-2015, 01:36 PM
the hose isn't necessarily broken though, just the air intake tube.
Old 05-19-2015, 01:39 PM
right, take off the broken rubber from the metal tube and all you need is an air intake tube
Old 05-19-2015, 01:43 PM
6th Gear
Awesome! Thanks for the help
Old 05-19-2015, 01:47 PM
Chojun's Avatar
Yep if you are going to spend any money then drop in a Cold air Intake (preferred) or Short Ram Intake.
Otherwise try to find one off a TL in a junkyard or whatever. But don't delay as currently you're sucking unfiltered air into your valve train. If it's been broken for a while you may want to change your oil filter when you get the new intake installed.
Old 05-19-2015, 04:46 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
^ That metal tube doesn't suck air though.. Its the air tube when connected that sucks oil fumes from the valve train to the manifold.
Old 05-19-2015, 05:00 PM
^but throttle body is right there, no?
that hole next to the throttle body has to be sucking up dirt, as you can see the plastic cover is covered in dust
Old 05-19-2015, 06:01 PM
Chojun's Avatar
?? It's a mystery ?? Does it suck or blow? Anyone care to find out
Old 05-19-2015, 06:20 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
the big problem is the open TB inlet- the system is made to be sealed from the air filter box to the TB
I don't see a hose clamp on the TB end of the intake tube? is it my eyes?
is there some back-story here that we need?
Old 05-20-2015, 09:27 AM
TLer trash's Avatar
Just get it fixed asap. The metal tube supplies make-up air that the pcv system is removing. Any air flow, along with dirt, is going into the valve cover, and eventually the crankcase and oil.
Old 05-20-2015, 06:41 PM
01tl4tl's Avatar
like I was trying to explain, the open` TB to air snout to air filter` is like having NO air filter at all!
Biggie_B
02-26-2017 11:14 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
juanrl
09-29-2015 03:25 AM
Quick Reply: I know my air intake hose is broken but...
