03 tl-s overheating..please help - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 09-20-2012, 03:18 PM   #1
Registered Member
kambo_inspire's Avatar
Ok so I've replaced the t stat and did a radiator flush..but the car still overheats,I've read something about a bleeder valve but I don't kno where its at.I think it might have air in the system but idk also when it overheats the overflow tank boils..someone please help
kambo_inspire is offline   Reply With Quote
Old 09-20-2012, 03:49 PM   #2
Registered Member
MilwaukeeDave's Avatar
If its boiling I think there's a leak somewhere. It shouldn't boil unless the pressure is reduced. That's why when it's hot and u take the cap off the antifreeze boils up and out due to increase of pressure.
MilwaukeeDave is offline   Reply With Quote
Old 09-20-2012, 04:06 PM   #3
Registered Member
Ok so any suggestion on where to start looking for a leak?? And don't kno if this is related but b4 the car started to overheat I was driving about 85-90mph on the freeway and ran over some tire debris..u think this could've caused my radiator to crack?? There IS no leak tho that I notice coming from the radiator area
Old 09-20-2012, 05:53 PM   #4
Registered Member
how does the temp come up- normal temp then suddenly hot?
road debris will put a hole in rad!!!
are both rad fans running? driver fan run a few times at stoplights
special tool need to pressure test for leaks- go to a radiator shop
Did you use a honda genuine thermostat==tl picky about that and its position
Burping the system after filling
see owner manual for specifics to your year ,get one free www.owners.acura.com need cars VIN for that
heater must be turned on to hot
you run engine with rad cap off, fill system as needed,,takes 10-20 minutes to be sure its all done
air will cause many problems
01tl4tl is offline   Reply With Quote
Old 11-22-2012, 10:42 AM   #5
Registered Member
mrbustrbrown's Avatar
make sure both fans kick on,mine was overheating too,overlooked the fan and spent alot of money,even new radiator....let idle and wait and see or idle and turn ac on and both fans should be on,if not then buy just a new motor for the fan that doesnt kick on and swap em,problem solved...note..easier to do when u take radiator out
mrbustrbrown is offline   Reply With Quote
Old 11-22-2012, 11:26 AM   #6
Registered Member
i have a 2002 acura tl i rebuilt the trans myself i recently put the trans back in my car the speddometer doesnt work and i wont go out of second gear please help
kuba12 is offline   Reply With Quote
Old 11-22-2012, 12:11 PM   #7
Registered Member
this is a thread about overheating,,not `my trans wont shift!`
please make new thread- `I rebuilt trans- but it wont work`
,,one of our trans gurus that have rebuilt them may be able to help
usually no shift after rebuild is a line not connected or an internal problem with incorrect assembly, clutchpack issue, or bad part
same with speedo
did you install 7.3 qts of honda dw1 atf?
being a holiday today dont expect an immediate response with factual answers too quickly,,but kris and the piggylover should be back soon--those guys know inside the trans
Thread Thread Starter Forum Replies Last Post
How to remove the bluetooth from 2007 TL ? MetalGearTypeS 3G TL Audio, Bluetooth, Electronics & Navigation 6 08-29-2016 09:28 PM
2008 TL Type-S restoration underway! LogicWavelength 3G TL Photograph Gallery 33 11-01-2015 10:38 AM
Dealer adding Exhausts Timmy18 Fifth Generation TLX (2015+) 78 10-17-2015 04:58 PM
Farewell to the 3G Acura604 Third Generation TL (2004-2008) 10 09-28-2015 01:24 PM
TL Shirts Available? UA7_Ando Third Generation TL (2004-2008) 10 09-28-2015 08:53 AM
Tags
03, 2001, acura, area, cl, donate, houston, overheated, overheating, powered, quickly, tl, toys, tx, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
