02 acura tl 5th gear blinking, no 5th gear - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 01-22-2006, 08:33 AM   #1
Registered Member
Today my panel was blinking non stop, showing green light on 5th.
My transmission will not shift to 5Th gear and no manual shifting at all.
Any ideas??
Thanks...
marcelo is offline   Reply With Quote
Old 01-22-2006, 03:58 PM   #2
Registered Member
Ryons02TLTypeS's Avatar
i think u gotta prob buddy, remmeber rradin it b4.. about the deadly blinkin D5
Ryons02TLTypeS is offline   Reply With Quote
Old 01-22-2006, 05:18 PM   #3
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
The transmission is dead.
03CoupeV6 is offline   Reply With Quote
Old 01-22-2006, 07:12 PM   #4
Registered Member
I find out today that my car alarm PURSUIT mod: pro 9232s was interfering with my car electrical components, like my tranny computer. As soon as I remove this alarm the problem was solved. I note that everytime the trunk door was open the 5th gear green light would not blink after I started it again and as soon as I open the trunk door the 5th green light would go on and off again. I guess I luck it out.
Old 01-22-2006, 07:20 PM   #5
Registered Member
So I had to turn the ignition key on everytime I open and close the trunk.
Old 01-22-2006, 07:22 PM   #6
03CoupeV6's Avatar
Okay.. weird.
Old 01-22-2006, 08:19 PM   #7
fsttyms1's Avatar
And just for the record a Flashing D5 light Doesnt necessarily mean the tranny is dead. It can mean a # of things.
fsttyms1 is offline   Reply With Quote
Old 01-22-2006, 10:41 PM   #8
Registered Member
I was wondering is there is anybody with a t5 flashing light that end up no being such a too bad of a problem? , like the one that a had with the Pursuit car alarm. It would be nice to know.
Old 01-22-2006, 11:09 PM   #9
fsttyms1's Avatar
I had a Blinking D5 light and it was a tranny temp sensor. Easy to replace. Like i said it blinking doesnt mean that its a dead tranny for sure. There are other things it could be.
Old 01-24-2006, 03:18 AM   #10
Registered Member
NYanks78's Avatar
I had the same problem just now, and it was werid cause the car was hesitating in first gear and then the blinking light came on at 5th gear. Then I went to park and my reverse wounldn't work. Then I restarted the car and it worked but hesitating was still their, now I dont know what to do. I think this is the tranny and I have a warrany and gonna bring it to Acura, but wanna know if Anyone ever hear or expirenced this and have any suggestions....
NYanks78 is offline   Reply With Quote
Old 06-26-2008, 03:56 AM   #11
Registered Member
Quote:
I had this same problem this evening. What did you come up with?
sturgeongeorge is offline   Reply With Quote
Old 06-26-2008, 11:36 AM   #12
Registered Member
Quote:
did that sensor cause the transmission not to shift properly?
Old 06-26-2008, 01:46 PM   #13
4G TL-Elilte, 3G MDX
Pull the fault code(s) out from the PCM. That's the only way to find out what exactly is the problem. Much better than pure guessworks.
Edward'TLS is offline   Reply With Quote
Old 06-26-2008, 01:49 PM   #14
Registered Member
pulled code p0720
Old 01-19-2013, 04:15 AM   #15
New Member
I had that same code P0720
Quote:
Originally Posted by sturgeongeorge View Post
pulled code p0720
What does it mean? My car has went into gear 2 time now it wont move at all. When I drove it last the D5 light was blinking when I got up to 10mph?? Can any one help me out?
h8shwz is offline   Reply With Quote
Old 01-19-2013, 08:09 AM   #16
Registered Member
Hey H8shwz, ya pulled up a rather old thread......but to answer your question about the code P0720 : It's indicating a potential problem within the Countershaft Speed Sensor Circuit. Are you getting any other codes ?
Check the MAP sensor, if ok...then inspect the Countershaft Speed Sensor wiring harness connector. Could be loose or corroded, maybe a poor ground or shorted. Clear the codes and see if the CEL comes back on. It could be that the Countershaft Speed Sensor is faulty and needs replaced ?
3.2TLc is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Photography Gear Deals. *No Commenting* asianspec Cameras & Photography 16 01-27-2017 05:37 PM
Photography Gear Deals *Commenting section* asianspec Cameras & Photography 25 09-13-2016 03:59 PM
AV6 "swap" in progress, trying to get the old trans out.. justin7779 2G TL Problems & Fixes 8 12-25-2015 11:33 PM
2000 Acura TL 3.2 Reverse (Only) Slips Under Load Mike Bertram Second Generation TL (1999-2003) 9 09-10-2015 10:27 AM
FS: 2005 Acura TL Anthracite Metallic San Diego, CA asahrts Member Cars for Sale 0 09-04-2015 06:55 PM
Tags
02, 2000, 9232s, acura, blinking, code, d5, flashing, green, light, p0720, pro, shift, tl, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
