Hairymonkey019 Progress Thread (SLOWWWW progress, but pic heavy)
Old 02-23-2012, 03:31 PM
  #41
Flagship Aspec
tc5280's Avatar
dude you don't need any of that, take a picture of everything that came in the box, there's got to be something other than what is in the picture about. It should have been bread tied to the bulbs.
Old 02-23-2012, 03:47 PM
  #42
HairyMonkey019's Avatar
they sent me this
"Hi Francis,
Thank you for the email.
A pair of D2S adapter wires should have been included with your shipment. These wires would allow for the bulbs to connect up to the ballasts.
I will go ahead and ship out the adapters that should have been included with your order."
the bulbs were not tied to anything. they came in a box with just the bulbs.
1 big box contained 3 smaller boxes:
2x for each ballast
1x for both bulbs (which had no cables whatsoever)
I already said that no wires came with my order, other than the ones sticking out of the ballasts.
plus in the other thread, the guy says we need it...
Old 02-23-2012, 04:04 PM
  #43
Flagship Aspec
tc5280's Avatar
My bad man I have just never seen where they didn't come with and have never had to order other harnesses, good luck
this is what mine looks like: the ones with connectors go from the ballast to the bulb, and the ones with electrical tape are from the ballast to the stock wiring harness where I spliced it:
this is the connector that goes from the ballast to the stock harness. I cut off the 2 amp connectors just like the ones on the left in the picture above to splice it in
Old 02-27-2012, 02:06 AM
  #44
Small update. Chrome amber turn signals
Old 02-27-2012, 02:13 PM
  #45
Regional Coordinator (SoCal)
xtremex626's Avatar
you should take off the yellow tint on the fogs, it'll flow alot nicer with your cleared headlights, trust.
Old 02-27-2012, 10:42 PM
  #46
been thinking about it, but i'll eventually get to it haha.
Reminds me of when I was roaming around the forums and saw that JDMinspired went crazy on with overlays
JDM Inspired (02-28-2012)
Old 02-28-2012, 08:06 AM
  #47
JDM Inspired's Avatar
^lol word I had my days, now my overlays are off as well as my ambers lol....
xtremex626 (02-28-2012)
Old 03-02-2012, 09:43 PM
  #48
3 Pictures.
Took two days to finish but I got it done.
I Had to splice my OEM harness to the DDM tuning adapters, which as you can see black-to-black & blue-to-red (for driver side)
First test run, for 10 seconds PERFECT!
Finally just adjusted the lights, took forever, but I finally got my Low beams working.
-6000K DDM tuning bulbs
-DDM tuning ballast/inverter
-DDM tuning adapter cables
-TheRetrofitSource amps/igniters
No flickering, and light output is pretty even
Old 07-10-2012, 01:28 AM
  #49
Guess, what I'm about to pickup tomoro
02type-s (07-10-2012)
Old 07-10-2012, 09:38 AM
  #50
MechEng
03tLsNBP's Avatar
wheels or coilovers
Old 07-11-2012, 08:41 PM
  #51
FF1's baby
Gonna do work on saturday
and other great news, I WON A TICKET TO AUTOCON, so I'm now officially going for free
Old 07-11-2012, 11:22 PM
  #52
xtremex626's Avatar
please tell me you're slamming it francis
Old 07-12-2012, 12:46 AM
  #53
haha, let's say I'm going as far as i can. and i have never driven a slammed car before.
did u have any problems wen u were slammed? or did any fender work?
Old 07-12-2012, 01:51 AM
  #54
n1njai's Avatar
Lol. You'll learn quickly that if you wanna roll low, then you gotta roll your fenders or remove the fender lining. It's gonna rub like crazy despite being on stock wheels.
Old 07-12-2012, 09:36 PM
  #55
xtremex626's Avatar
lol yes i did. there are no such thing as no problems when you're slammed. you gotta avoid potholes, go slow on speed bumps and dips, etc. you also are going to experience your UCA (upper control arm) smacking which gets annoying but hey.. something you can't control unless you cut a hole in your stut tower. you're gonna bottom out on freeways (i remember i sparked several times) and if you're low enough (which i doubt you'll be on stockies), you might crack your oil pan.
when i was slammed, i went as low as i could in the fronts. i was rubbing like a mofo whenever i tried making full turns, but the rears i could've gone alot lower but didn't want to cause it looks weird on the 2g's to boat it (reverse rake).
as for fender work, you don't really need any if you're just going to be slammed on stock wheels.. it's pointless imo. the front fenders are almost already rolled (at least for me since i kept rubbing against it). i bent the tabs upwards a bit and i just pulled the front fenders out as much as i could using my two hands and that was enough for me to as low as i wanted to go in the fronts.
HairyMonkey019 (07-13-2012)
Old 07-13-2012, 02:50 PM
  #56
^^exactly what I needed
Thanks a bunch.
Tomorrow night there should be pics, if not then on sunday
Old 07-15-2012, 05:47 PM
  #57
So far I'm enjoying the height, but how slow do you guys go on ff1's when on the freeway?
Cuz I now go about 50-60 lol, and scrape every now and then... so far
Old 07-15-2012, 06:15 PM
  #58
MechEng
03tLsNBP's Avatar
I just did normal speeds (65-80) and prayed.
But now I'm not slammed anymore and my life is a lot less stressful
Old 07-15-2012, 09:03 PM
  #59
n1njai's Avatar
^+1, I just drive normally. 65-75. U scrape, u move on with your life. You pay to play. Don't bitch and moan when you scrape a little bit.
xtremex626 (07-16-2012)
Old 07-15-2012, 09:36 PM
  #60
just wanted to make sure, cuz now i've decided to stay at this height. though i do moan,i really enjoy it
Old 07-16-2012, 04:27 AM
  #61
3 pedals in my 99 TL
mugenspire's Avatar
looks good now kit her up!
Old 07-16-2012, 01:49 PM
  #62
xtremex626's Avatar
not to brag, but i've been over speeds above 75mph. just be careful on random inclines and declines (ie. the 605 n/s freeway), you will smack your UCA like crazy.
Old 07-16-2012, 02:22 PM
  #63
thanks for the input henry, will definitely keep that in mind.
and after searching on acurazine, looks like imma be going to wheel house tire soon for my alignment!
Old 07-16-2012, 08:47 PM
  #64
xtremex626's Avatar
^ask for johnny dip. tell him henry with the black LS sent you!
Old 07-16-2012, 09:22 PM
  #65
xmikojaix's Avatar
fuck yea looking sick bro! driving slammed everyday not that bad lol
HairyMonkey019 (07-17-2012)
Old 07-17-2012, 01:14 AM
  #66
i asked for david aka dstah, was very helpful.
I'm definitely coming back here for alignments and tires, great prices!!!!
WHEEL HOUSE TIRE FTW!!!!!!
Being slammed, FUCKIN AWESOME, it feels sooo goooood, and im driving normal speeds now.
YOLO
Anyways, has anyone ever had an issue where something in the wheel well is like possibly picking at the tire when the car bounces
cuz here's what i'm concerned about. it pretty much has a small trail on both front tires. its not deep, but it worries me cuz i don't wanna pop my tires
yes.... I know they're bald, gonna replace em asap
should i raise the front a lil? wat would u guys recommend if anything?
Old 07-17-2012, 08:13 AM
  #67
deal with it
dreem1er's Avatar
Find out where its rubbing, then remove the trouble spot, if it can't be removed maybe change tire size or rise it
Old 07-17-2012, 09:30 AM
  #68
MusicBox12345's Avatar
i have that same problem with mine i also dropped on ff1s too how to like the ride i love it but yeah im thinking about lower profile tires too because i need new tires let me know what you decide to do and how you like it
Old 07-17-2012, 12:35 PM
  #69
Since im going to busy wiith work, imma check undeer to see wats causirng it on thursday or friday, if i can cut comething off or remove i'll do so.
If u went to lower profile tires, wat size would u go for?
Raising it is something id rather not do
Old 07-17-2012, 03:53 PM
  #70
deal with it
dreem1er's Avatar
Depends how much you need to clear, but remember changing tire size throws off the Speedo
Old 07-17-2012, 05:18 PM
  #71
Totallly forgot about that, then most likely imma remove/cut w/e needs to be gone, and if i cant, im goin up 1/4 inch
Old 07-18-2012, 11:56 PM
  #72
i raised the car 1/2" idk wat the problem was, the only thing i suspected was the metal tab that the fender liner hooked up on along the firewall, i banged that in with a hammer just in case.
the car used to be raked very slightly, but is now even f/r
Old 07-19-2012, 12:04 AM
  #73
xtremex626's Avatar
it's most likely the metal tabs sticking out that get in the way when you're making a turn hence the cut tire. shouldn't be anything else that could be cutting it.
and you should go with a lower tire profile for all 4 if you're really looking to slam. original tire size is 215/50/17, go for a 215/45/17.
Old 07-20-2012, 02:10 PM
  #74
i think imma stick with the original size.
being low shoulda been my first mod lol
Old 07-20-2012, 03:25 PM
  #75
xtremex626's Avatar
^yep haha. first thing you should ever do to your car should be to lower it! it's the most expensive next to wheels but hey.. all the little small accessories and mods can fall after coilovers.
Old 07-21-2012, 12:40 AM
  #76
speaking of wheels, i just picked up a set of 04-06 tl wheels(always wanted them)..... talk about a big difference lol.
like post#72 says with stock rims I raised the front 1/2 inch and didn't have to angle going up my driveway (had very little clearance tho), with the 3g wheels on i have to angle again lol.
Right now only the fronts have 3g wheels.
Will have pics later on.
Old 07-21-2012, 02:56 PM
  #77
Old 07-21-2012, 03:29 PM
  #78
mugenspire's Avatar
gonna look tight when you have all 4 wheels matching. probably gonna have to roll the rears a little to make the 04-06 wheels fit. my homie has the same set up on ff1 and 3g wheels and his rears are rolled slightly. although he is much lower than you. looks good though. ever think of getting oem visors instead of weathertechs?
Old 07-22-2012, 02:17 PM
  #79
I read on the 2g tl with 3g wheels thread that i would need to cut bumper tabs.
as for the visors, I'm fine for now, $100 weather tech>$200 oem for visors haha
Old 07-23-2012, 11:20 PM
  #80
xtremex626's Avatar
think of it this way.. $100 more and you'll be dropping panties to the floor.
Quick Reply: Hairymonkey019 Progress Thread (SLOWWWW progress, but pic heavy)
