Who Has A 2nd Gen TL supercharged
Old 11-08-2016, 10:31 AM
R2D
R2D's Avatar
Hey Guys,
I'm looking to get some info on how much power our TL will make with a comptech supercharger kit on... I have spent hours searching and i haven't wound much. Mainly looking to see what WHP and TQ we can make with this kit on.
Any info would help thanks guys!
Old 11-08-2016, 10:36 AM
Received 16,260 Likes on 11,971 Posts
0HP if the transmission fails.
that will be your biggest problem. the 2nd gen TL tranny isnt stout to begin with and FAILS with stock power. Let alone, adding an additional 30-40hp will kill it quickly.
swap a six speed manual tranny in the car and it will automatically make the car faster and more reliable.
Old 11-10-2016, 12:08 PM
3.5 psi
gnuts's Avatar
i think comptech had dyno numbers on their site for the auto. I just checked their site and it says 40-60whp depending on the application. So it's probably 40 for auto, 60 for 6speed. I'm guessing you gain about 40wtq as well. There are dynos on the CL side (dyno section) you could look up.
You're better off throwing in a J35A3 with an accord trans. and staying N/A.
The following 2 users liked this post by gnuts:
justnspace (11-10-2016), teh CL (11-19-2016)
Old 11-10-2016, 12:12 PM
that CT blower is so inefficient
Old 11-14-2016, 09:43 AM
3.5 psi
gnuts's Avatar
It is! Gerzand's rotrex looks amazing. That's the kind of power 5G should be getting you. Mind you, a used CT blower for ~2.5G, bolt on is not a bad go.
Old 11-19-2016, 10:14 PM
R2D
R2D's Avatar
😂 Right, if the trans go's then 0 everything... for now the car will stay a auto till I find a 6speed swap..
Old 11-19-2016, 10:17 PM
R2D
R2D's Avatar
thanks for for the info I just saw the same numbers on the website... not building a race car but I'd like to add a little more power to it. Only reason I'm doing this is because I got a great deal on a complete SC kit. So I couldn't pass this deal.
Old 11-19-2016, 10:20 PM
R2D
R2D's Avatar
Didn't pay nothing close to 5g. But I'd think the SC should put out some good power. Not looking for anything crazy.
Old 11-19-2016, 10:50 PM
Received 8,583 Likes on 6,630 Posts
I would do a 6MT swap before the SC
Old 11-22-2016, 10:59 PM
03 tls nc's Avatar
The Comptech SC kit with a custom pulley will make some impressive power. The kits caught a lot of flack for being conservative but in base form it would not void the factory Honda warranty. It was also said that the m-62 was to small for a J35A3 which is not the case at all. It is however, a positive displacement blower so you will not see big boost numbers, but the kit with added supporting mods is more than capable of getting you in the 400 whp range.
As for the trans, pick your poison, (6-speed, AV6, built TL) that is solely up to you. The Auto trans with the right components used can handle the task (change fluid regularly).
justnspace (11-23-2016)
Old 11-24-2016, 03:22 PM
R2D
R2D's Avatar
thanks for the info.
I will have to get a custom pulley made since the one that comes with the SC kit is I think only 7-8 psi... I'd like to do 10psi with all my bolts on's and see what numbers I get. For now I will be on my stock auto trans.. long term plan is to get a CL 6 speed trans 👌.
I will need to dyno the car car now with what I have to see the difference since the SC is on the car
Old 11-25-2016, 10:05 AM
3.5 psi
gnuts's Avatar
no the stock pulley that comes with the kit is 3.5psi. The high boost pulley (HBP) is about 6psi. Anything more than the regular pulley will require tuning and removal of the comptech ESM. Start with the regular pulley and go from there. I don't think your trans will hold up very long though so have some trans money ready.
One member years ago made 369whp/310wtq on 7-8 psi with a top mount intercooler. I would suggest some cooling - water/meth or intercooler - if going above the regular pulley. My intake temps get pretty high on the regular pulley.
South Florida Pulley will make a custom pulley.
Old 12-14-2016, 09:45 PM
03 tls nc's Avatar
The ESM will be fine with a HBP but you will have to turn the fuel pressure up. The need for tuning comes when you cool the charge air, the ECU can not compensate because it needs a lot more fuel with the denser air. The high intake temps cause the ECU to pull timing and protect the motor. If you can loose the cat do so and run a 3" exhaust to help keep cylinder temps safe. Removing the fog light or dummy duct will help lower intake air temps also. If you keep an eye on the fuel pressure and AFRs while you get the fuel pressure set you will be fine with the HBP on ESM. Had my pulleys cut by South Florida Pulley, they are awesome!
Old 12-15-2016, 09:07 AM
3.5 psi
gnuts's Avatar
that's true, I don't know why I said you have to tune with the HBP. Obviously that's ideal, but many members have run or are running the HBP with the ESM. Are you on the HBP? What fuel pressure have you set with it?
I don't think you'd have to tune if you put on a front mount air-air intercooler would you? If the engine can compensate for the s/c why can't it handle the same thing but with cooler air?
Old 12-20-2016, 11:04 PM
03 tls nc's Avatar
I had 2 HBPs cut by South FL Pulley, Boostedorbusted is running one on his 3.5 and I have not put mine on yet. Not sure of his fuel pressure but hes is only using the ESM with no issues.
When you cool the charge air it becomes denser and requires more fuel. This is where the Greddy Blue and some big injectors comes into play. The ESM and FMU is only good below a fuel pressure of 90-100 psi at which point the injectors become failure prone and the chances of running lean are great. For fuel economy these engines are designed to operate with a high intake air temp and with the FMU artificially adding fuel the ECU stays happy.
Old 07-17-2023, 09:15 PM
Barry Richards's Avatar
Still have supercharger
Hi I am looking for a supercharger for 2003 Acura Cl type s,thanks
Old 08-07-2023, 01:03 PM
Received 1,736 Likes on 1,392 Posts
Here's one, you might be able to fit it to your 2G CL if it is a manual trans:
Comptech Supercharger | eBay
Old 08-13-2023, 08:28 PM
Alternator/SC Comptech pulley
Hi I am trying to source the alternator/SC Comptech pulley for 2003 Acura J32A2 6 speed thank you.
Old 08-13-2023, 09:18 PM
Good luck with that!
CT-E's standard alt. pulley originally included with the S/C'er kit on the left, high boost alt. pulley supplied separately on the right.
kyamcg
145
12-11-2019 05:48 PM
ziggyh22
08-08-2012 02:33 AM
dudeinaTL
02-21-2011 12:01 AM
SheckyZ28
10-17-2004 02:33 AM
acura516
04-29-2002 10:36 AM
Quick Reply: Who Has A 2nd Gen TL supercharged
