2nd Gen TL auto transmission alternatives?
Old 01-02-2014, 07:26 AM
  #121
i love my CE1
4Door's Avatar
^^ i never had the shop flush the trans, they just topped it off as it was a tad low...
to answer your question a lil better...
we had a super cold night, next morning i went to the store and sitting at a stop sign in my neighborhood i gave it a little gas and it felt like i had inadvertently shifted to neutral so i moved the shifter down to what i thought was drive (put it in D3) and back up to drive (5)... I continued to the store with out issue but that made me think and i needed an oil change any way...
i really thought the cold weather froze a solenoid or some other stupid little thing happened...
that was the only time it slipped before going out all together while on my trip...
4Door is offline
Old 03-05-2014, 10:28 AM
  #122
3.2 CL-S Sundance Gold
Gregory_20706's Avatar
My tranny went on an 01 CL Type-S I bought a tranny off of what looked to be an 03 TL Type S. Guy is tellinig me the tranny isnt working because it has different gear ratios which I never heard in my life. He is saying the tags on the tranny are different. I need BGFA tranny instead of the V7W4 tranny I now have sitting in CL. The digital gear read doesnt even come on when in Tiptronic. HAs anyone ever heard of the trnny being wrong. What is a suggested fix. Simply switching the sensors??
Gregory_20706 is offline
Old 03-05-2014, 03:51 PM
  #123
no help??
Old 03-06-2014, 06:55 AM
  #124
3.2TLc's Avatar
A 5 speed AT from a "TL-S" should work fine in a "CL-S".
Perhaps the gear selector switch needs adjusted ?
If the tranny is from an '03 TL, it may be simply something overlooked during the installation process. Recheck the work and connections.
It's after the fact......but the ideal donor replacement has been the '06>'07 AV6 tranny.
3.2TLc is offline
Old 03-06-2014, 11:57 AM
  #125
Thanks a lot...i am thinking its an install error as well. Gonna maybe try switching a few sensors after having someone else 1st check behind initial install.
Old 03-06-2014, 11:58 AM
  #126
Couldnt locate a decent priced AV6 tranny in my area...FML
Old 03-18-2014, 09:11 PM
  #127
coronaman's Avatar
Originally Posted by phee
the 3rd gen tl transmission will bolt up as long as it isnt the 3rd gen type S.
it will run in limp mode.
however! if u swap the sensors from the 2nd gen tranny it will be fully functional. the main reason it works is because u are putting the 2nd gen range switch on it.
its been done and one of our members p.diddy was going to do it again.
its a good alternative for those of u who are out of warranty.
nva-av6 (paul) has done the swaps on accords.
this will not work on the 99 tl's with the 4 speeds
Will the 3rd gen type-S fit the 02 type-S
coronaman is offline
Old 03-28-2014, 03:29 PM
  #128
You said the ideal replacement is a 06/07 AV6 tranny I found a 2005 will low miles. Its still considered a 7th Gen so why is the 06/07 preferred besides the fact that its newer. Is the configuration different?? Any problems i should know about the 2005 Accord tranny?
Thanks in Advance
Old 03-29-2014, 11:41 AM
  #129
coronaman's Avatar
Does the shifting components from the 5at and the gauges still work with the av6 swap or do they need to be changed/modified?
Old 03-29-2014, 12:38 PM
  #130
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
AV6 is almost identical to our B7WA (Our stock trans) physically its identical to the TL-S trans main difference is that it doesn't have the speed hole for the Power Steering system for TL-p users..
With TL-S you need to compare them side by side and look at the components swap everything from your stock trans to AV6 including the ATF warmer and done!.
With TL-p just need to cancel the speed thingy from the power steering as an added step.
AV6 trans have relatively the NORMAL amount of dead trans history which means its okay every car has a bad apple from time to time not a fucking farm full of them like in our case... don't worry about the details it gets better, much better.
Skirmich is offline
The following 2 users liked this post by Skirmich:
coronaman (03-29-2014), Tstyle27 (05-15-2014)
Old 05-28-2014, 01:21 AM
  #131
8th Gear
Roguej32's Avatar
this is awesome
Roguej32 is offline
Old 05-28-2014, 07:36 AM
  #132
3.2TLc's Avatar
Thumbs up The AV6 is awesome !!!
Originally Posted by Roguej32
this is awesome
Yeppur, the "AV6" donor breathes new life into our old ailing 2nd Gen TL's.
3.2TLc is offline
Old 02-01-2015, 12:27 PM
  #133
revint's Avatar
are you guys talking bout auto or manual transmissions
revint is offline
Old 02-02-2015, 12:14 AM
  #134
Skirmich's Avatar
^ AV6 is an AUTO.
Manual Swaps are more expensive to do and requires some mods on the TL.
AV6 is basically plug & play.
Skirmich is offline
Old 06-19-2015, 12:37 PM
  #135
Santiago Trabuco's Avatar
hoping i didn't miss the answers and ask the same questions again:
so the question remains of whether the 2005 av6 is the same as the 2006/2007?
also, is the 3g tl transmission or the ody transmission less desirable/ideal than the av6?
Santiago Trabuco is offline
Old 06-20-2015, 04:09 PM
  #136
Haze1092's Avatar
Originally Posted by NVA-AV6
Ok, without reading the whole thread here is what I have done and what I know can be done....
First, it is stright forward to put in a 3rd gen tl/7th gen AV6/03-07 oddy tranny in a 2nd gen TL provided that the TL was a 00+ which had a 5spd in it already, everything bolts up but you will have to transfer a couple of parts from your old tranny, the trans range switch and the oil cooler/filter assembly, other than that it is a stright bolt up. Now if you have a 4spd TL/CL you will also have to get a new engine wire harness and ECU from a 5spd TL/CL and may* have to do a little repin/rewire for the chassis connection to the ECU.
I read most threads say 06-07 accord v6 but is it possible 04-05 why does no one answer this question aren't they the same trans?
Haze1092 is offline
Old 12-21-2016, 09:17 AM
  #137
Michael Hinchey's Avatar
so I have a 2002 3.2 Acura TLS automatic and of I get an oddly tranny of yrs 03-07 6 speed automatic. It will just bolt up with a few reused parts from the Acura?
Michael Hinchey is offline
Old 12-21-2016, 11:32 AM
  #138
Received 8,577 Likes on 6,627 Posts
https://acurazine.com/forums/second-...n-swap-905115/
thoiboi is offline
Old 12-22-2016, 04:54 PM
  #139
Pop's Wheels
therealjgall's Avatar
Originally Posted by kyamcg
Hey everyone.. Here's what I'm thinking...
I've seen a few threads about people that are replacing the stock transmission with a 6-speed, but I was wondering what automatics would fit in our cars easily.
So do the 04+ TL and Accord automatics fit right in as well?
I'm just hoping once people answer this, it can serve as a nice reference for at least SOMEONE out here.
Never heard of swapping in the 3G six speed, I've only heard of using the CL-S six speed. Is the 3G 6MT also a viable option? I'm assuming it would be easier to come by.
therealjgall is offline
Old 12-22-2016, 07:00 PM
  #140
mike_engr's Avatar
Anyone use the 05/06 Odyssey instead of 06/07 AV6?
Do you have a picture of the drill/tap location that some posters say is necessary?
mike_engr is offline
Old 01-24-2017, 11:14 AM
  #141
Santino Patterson's Avatar
D5?
Originally Posted by fast_eddie
My buddy just threw a 06 Oddy trans in my 02 TLS, so far its running nice and smooth. Its only been a few hundred miles, but it jus feels good to have my baby up and running. Oddy trans was almost half the price of AV6 or 3rd gen TL trans with similar milage.
I was just wondering if u got the oddy transmission to work in D5 ?(when u push it over to shift gears urself) does it say 5 when you hit 5th gear? Or do u gotta mod that too? Cuz I was thinkin of droppin' oddy or a type s tranny in my 99TL.
Time to upgrade to a 5 speed.
Santino Patterson is offline
Old 03-24-2017, 03:07 PM
  #142
Ugly03's Avatar
I've been reading and trying to understand all the info in this thread and I think I have a grasp on some of it.
I've already had my transmission rebuilt once before I knew these cars just had bad trannys. It's starting to give me a little trouble so I started looking. Will this fit? The ad says 2003-2007 Accord V6 transmission...
https://batonrouge.craigslist.org/pts/6032278514.html
Ugly03 is offline
Old 08-19-2017, 07:12 AM
  #143
Ahmed Nomaw's Avatar
Ok so instead of putting in another stock tranny, you can put in an 04-08 TL (non type-S) transmission by just replacing the sensors. Good to know! Is it hard to swap the sensors? If not, this seems like a good alternative.
I have done this auto trans swap on 01 CL, the trans is from a 06 Tl. there are some swap parts that are involved but nothing major
1. Reuse the range sensor from the original trans
2. Subframe, 2 gen trans mounts
3. A,B,C and D sensor wire harness
4. Reuse trans Cooler from 2Gen trans (3Gen Cooler is mounted backwards).
That's what I can remember so far, but check my thread out. I have listed the details there.
Ahmed Nomaw is offline
Old 02-07-2018, 05:58 PM
  #144
5th Gear
Klkids's Avatar
I have a 2000 Acura TL type a I wanna do a manual swap what’s the easiest route I heard about the cl manual tranny but now am seeing that the Acura TL 3 generation manual tranny which one is easier which cost less
Klkids is offline
Old 12-11-2019, 05:24 PM
  #145
6th Gear
Cali962's Avatar
I have a 02 tl type s blow tranny just wanting to make sure a 08 acura tl tranny will fit it
Cali962 is offline
Old 12-11-2019, 05:48 PM
  #146
your best/only bet. 08 will NOT fit.
thoiboi is offline
whitetiger5 (12-12-2019)
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
Frathora
09-28-2015 11:29 PM
carz0159
09-20-2015 06:11 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: 2nd Gen TL auto transmission alternatives?
