2002 TL-S 6speed swap?
Old 06-08-2010, 07:13 PM
boostedorbusted's Avatar
Question 2002 TL-S 6speed swap?
ok ive searched and search and cant clarify anything. i see a bunch that have done base to type-s motor and tranny. but i want a parts list of what i need to convert my 2G TL-S from auto to 6 speed. who has done the swap on there type-S already and what do i need to do this? thanks in advance.
Old 06-08-2010, 07:22 PM
desired_speeds's Avatar
please search next time, its actually stickied in the general section: https://acurazine.com/forums/2g-tl-1999-2003-98/6-speed-conversion-591872/
Old 06-08-2010, 08:03 PM
ok i read that one isnt it different becuase he went from base to a tl-s motor and tranny? i want to know what i'll need for my type-S?
Old 06-09-2010, 01:28 AM
thinhthan's Avatar
just read the part with the 6 speed
Old 06-09-2010, 05:21 PM
so i need every part on this list? correct
03 CLs-6 speed manual.
03 CLs-6 Manual Engine Harness. 32110-PGE-A11
03 CLs 6 speed ECU
03 CLs-6 Flywheel 22100-PGE-026
03 CLs-6 Flywheel bolts (Qty 8) 90011-PGE-000
03 CLs-6 Clutch Assembly 22105-PGE-305 (unfortunately right now there arent many options for aftermarket clutches)
03 CLs-6 Rear Engine mount and bracket 50810-S3M-A01, 50827-S3M-A00, BOLT (m12X25) 90166-S3M-A00
03 CLs-6 Rearand Front Engine Dampenerand bracket (i would reccomend aftermarket here)
03 CLs-6 Shifter and cables. 54100-S3M-A01, 54310-S3M-A01
03 CLs-6 Starter 31200-PGE-A11 (try to locate used, its expensive)
03 CLs-6 Gauges
03 CLs-6 Hydraulic Clutch lines. 46960-S3M-A01, & 46970-S3M-A01
03 CLs-6 Trans mounts (2 of them) 50806-S3M-A03, 50805-S3M-A03
03 CLs-6 Cup Holder 77230-S3M-A01ZA
03 CLs-6 Parking brake 47105-S3M-A04ZA and to go with it,
Spring 47537-671-670, Nut 47522-594-000, Equalizer pin 47365-538-000, Equalizer 47360-SB2-000
Front cam pulley 14260-PGE-A11
Front plate assembly (behind cam pulley) 11860-PGE-A10
Timing belt pulley(lower) 13621-PGE-A11
Crank shaft sensor 37500-PGE-A11 (this little shit costs $500.00)
Subharness for CKP 37501-PGE-A10
TDC Sensors (Qty 2) 37840-PGE-A11
TDC SUB HARNESS 37841-PGE-A10
If you decide to buy it new BRAKE PEDAL ASSY 46600-S3M-A51
If you decide to buy it new you will need the pedal and mount CLUTCH PEDAL 46910-S3M-A01 & CLUTCH PEDAL BRACKET 46990-S84-A01
MASTER CYLINDER ASSY 46922-S3M-A01 & Clutch Fluid Tank 46965-S5A-013, & Clutch Hose 46961-S3M-A02
(i used the one from the civic i pulled the clutch pedal out of)
Relay box assembly (under hood) 38250-S3M-A21
Shift Boot 83414-S3M-A01ZA
Shift Knob 54102-SL0-023ZB
You will be able to reuse the stock manifolds.
If you already ahve a Type-s you MAY Not need these????
Right side cabin to engine comp harness 32100-S3M-A12
Left side cabin to engine comp harness 32120-S3M-A20
Upper instrument harness 32117-S3M-A31
Lower dash harness 32150-S3M-A32
would i need these harness's aswell? it says youmay not need them , i need to know yes or no.
sorry if this seems like a retarded question i just wanna be 100% sure.
Old 06-09-2010, 05:31 PM
paton5g's Avatar
I am doing the CL-S 6MT swap into a '96 Integra. With this swap... you really do have to pay to play. I can't believe how expensive the parts are. There's also nothing you can do without. All of the pesky pricey sensors must be in place for it to run.
Old 06-09-2010, 08:49 PM
2000 acura tl FPR
assclown's Avatar
that's probably true for your teg, but it really shouldn't be that bad on the TL with RV6 harness.
03 CLs 6 speed ECU
03 CLs-6 Clutch Assembly 22105-PGE-305 (unfortunately right now there arent many options for aftermarket clutches)<<<---- not true, excelerate has many options for these, they are pricey though
03 CLs-6 Gauges not necessary
i changed the color of the parts that you will not need if you get the RV6 Harness to red, the other colors i've just put a note next to them. hopefully it helps. sorry i can't answer too many questions, i'm still in parts collection mode and i'm also doing the engine swap
Old 06-09-2010, 09:34 PM
now were talking info. what is this RV6 harness and were do i get 1?
Old 06-09-2010, 09:38 PM
2000 acura tl FPR
assclown's Avatar
not allowed to link to it on this site, just do google search for "6 speed obsession" and you'll find it. first link there.
Old 06-10-2010, 06:52 PM
AznWay's Avatar
He is also AZ vendor BTW
His Sn is Richie V6
Old 06-21-2010, 12:23 PM
Rejckt's Avatar
Here you go
Type-S to 6MT swap, no motor swapped.
https://acurazine.com/forums/2g-tl-1999-2003-98/my-tl-type-slow-6mt-7-8-psi-748551/
TypeS860
09-03-2021 06:42 PM
MetalGearTypeS
08-29-2016 08:28 PM
xsilverhawkx
09-28-2015 06:51 PM
hpfiend
09-27-2015 06:59 AM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: 2002 TL-S 6speed swap?
