Wheel Spacers for the RL here is the deal
Old 10-09-2014, 01:26 PM
JDMCRX's Avatar
Hey guys
I purchased some Diamond cut 19" and the RL calipers where to big so the challange begins.
I went thru hundreds of wheels studs and here is what i found that works.
5x120 spacers 10mm
m14x1.5 x 55mm studs
So guys I found a supplier in canada that can get these studs for a better price and was about week turn around.
I removed the bearing assembly for a few reasons. Very simple
New studs pressed into the hub.
The back of the rotor bolt holes have to be coned slightly .
Finaly all back together. I emailed the company who made the spacers so the next set are a little bit wider.
I will have the back done tonight.[/
The following 6 users liked this post by JDMCRX:
bluetl04 (11-06-2014), DeeQRL (10-09-2014), oo7spy (11-06-2014), projektvertx (11-06-2014), RL-SK8 (11-20-2014), tkosho24v (10-12-2014) and 1 others liked this post. (Show less...)
Old 10-10-2014, 08:21 AM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
quality work sir.
Old 11-06-2014, 07:37 AM
JDMCRX's Avatar
Well its been over a few weeks now and over 3000km and i checked today and no movement or stretching so we are good to go.
The following 2 users liked this post by JDMCRX:
HEAVY_RL (11-06-2014), oo7spy (11-06-2014)
Old 11-06-2014, 02:29 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
Thanks for sharing. Want to throw the members and the supplier a bone and give their info?
Old 11-06-2014, 03:08 PM
JDMCRX's Avatar
Send me a pm thanks
Old 11-06-2014, 03:13 PM
Received 16,260 Likes on 11,971 Posts
you know there are extended lug built in spacers, right?
Old 11-06-2014, 07:43 PM
JDMCRX's Avatar
Yes but the spacers are 3/4" most only need a 10-12mm
Old 11-20-2014, 11:14 PM
RL-SK8's Avatar
Thanks for info!!!!!
Old 05-27-2015, 10:53 PM
5th Gear
pashil's Avatar
Here you can find long studs.
Toyota Landcruiser 78 79 100 200 Series Long Wheel Stud 14mm X 1 5mm | eBay
Old 05-27-2015, 11:25 PM
JDMCRX's Avatar
If I remeber correctly would have to check but 16.25 Knurl
Was to loose !
Old 05-28-2015, 08:48 AM
5th Gear
pashil's Avatar
Orginal stud.
I have the original stud, I measured it 16.3mm...close enough for me
Longer vw stud is knurl 15mm, that is the only stud i can get in finland.
Spacers is 8mm front and 15mm rear.
Wheels are ecanto e112 19X8.5 et50
Honda Legend 2007
Old 05-28-2015, 09:49 AM
JDMCRX's Avatar
I had 2500hd studs that where 16.25 and they would not bite if you look at my other thread I took pics and tried them in the hubs.
Old 05-28-2015, 10:06 AM
5th Gear
pashil's Avatar
I weld studs or I'll put some toppings.
Old 03-08-2017, 10:02 AM
MayorMcCheese's Avatar
Bumping this since I need this
Why is it so difficult to find 10mm spacers? I don't like Akata either
Old 03-15-2017, 12:43 PM
JDMCRX's Avatar
motorsports-tech made me 3 sets of these spacers for different cars and there work quality is top notch. Its the studs you have to get.
Old 03-15-2017, 08:27 PM
anyone have a link to where to buy?
Old 03-20-2017, 02:36 PM
Geezey617's Avatar
Stud
Originally Posted by JDMCRX
Hey guys
5x120 spacers 10mm
Can u send the link for where u got the studs and spacers
Old 03-20-2017, 05:05 PM
Geezey617's Avatar
Originally Posted by pashil
Do it matter that it a toyota model? Have u done it and with spacers
Old 03-20-2017, 07:06 PM
JDMCRX's Avatar
those may work ill have to go measure my studs in the garage in a bit
Old 05-02-2017, 10:18 PM
fuzzysig's Avatar
so can i use the ebay adapters and press the studs out of them and use them as spacers instead?
the motorsports-tech custom spacers are like 180 plus shipping and bunch of other nickel and diming...
the ebay adapters are 120 shipped for all 4 hub centric 15mm adapters. is there a reason i shouldnt use those instead?
and JDMCRX can you post where you found cheaper studs please?
Old 05-03-2017, 05:37 AM
MSW 6SP's Avatar
I sent OP a pm regarding studs but he hasn't been in here in months
Old 05-03-2017, 12:13 PM
JDMCRX's Avatar
Hey guys the studs are only available thru me unless you find the supplier ! You can only go 10mm spacer unless you go with extended nuts you may get 2-4mm extra. I'm doing 12mm in the rear this summer and the Acura nuts off the TL will work safety .
Im working on my house right now and have 11 emails from
people about the studs !
The studs are around $200-220us depends on the us and Japan dollar !
if you are willing to spend the money to purchase them thru me then I can help you ! Other wise my buddy won't help ! Has to be thru me myself only
fuzzysig (05-03-2017)
Old 05-03-2017, 01:09 PM
fuzzysig's Avatar
sweet
thanks mang
Old 05-22-2017, 06:46 PM
fuzzysig's Avatar
what do you torque them to?
the spacer studs and wheel studs.
Old 05-29-2017, 06:15 PM
ChocBoyWonder's Avatar
Why are extended wheels studs so hard to come by? I need ones that are 65mm in length. The only ones that I've found to fit are the KYO-EI ones but they only make them 10mm longer than OEM. I need to run 20mm spacers to clear the calipers and things are looking grim...
Old 07-31-2019, 12:23 PM
Harold Crespo's Avatar
Wheel studs and spacers for Acura RL 2008
I currently had placed 1 in spacers to place some OEM Acura MDX 20 inch and the car drives very unbalanced.
where can I purchase the studs and the 12 mm spacer
mas well did you have yo do something to the rotors?
please help me out!!!
Old 03-11-2020, 04:54 PM
3rd Gear
RL GUY's Avatar
can you please tell me where you found the spacers and studs?thank you
Old 04-22-2020, 09:32 AM
Thaihang's Avatar
I know this is old post but can you still get them studs??
james357
02-13-2016 02:37 PM
obert
11-14-2015 09:59 PM
cammy5
09-04-2015 11:26 PM
mtl_ilx
09-03-2015 09:48 AM
Quick Reply: Wheel Spacers for the RL here is the deal
