Suspension / springs KB1 vs KB2
yes. the kb2 had higher-rate coilover springs
now if you're asking if you can mount the KB2 springs on the KB1, sure...you could transfer the springs over to the KB1 shocks/struts....
or you could compare the mounting points of the KB1 to KB2 and see if it'll mount. I dont think Acura changed the mounting points, as its the same exact car
Reason I ask is because I am looking for some lowering springs for my Legend KB2 (same as Acura RL KB2), and I can only get the springs for the KB1 here in Europe, not for the KB2.
But I want to make full sure if I can use them or not, before ordering
justnspace (12-02-2016)
rimini4321 (12-02-2016)
KB1 and KB2 suspensions are interchangeable. H&R will work just fine at the best price. It's been done here more than once.
rimini4321 (12-04-2016)
Are they different part numbers?
037 was one of the first to mod a KB2. Check here: https://acurazine.com/forums/2g-rl-p.../#post10906907
Something in the back of my mind is telling me there are two H&R part numbers for the different chassis, but I can confirm the parts are cross compatible.
Yeah, they are called 50116-1 and 50116-2 .... H&R says they are not same and the 50116-2 actually have to be manufatured after ordering ... but I see the link you made and it looks fine .... hmmm
