Snow tires?
Old 11-27-2016, 09:43 PM
stagefoursurvivor's Avatar
Snow tires?
I have read that if you put snow tires on any car you should decrease the size.
Despite putting a new set of Conti DWS06s on the RL a few months ago, I'm now considering putting snows on since my wife is a nurse and CAN"T take the day off regardless of snow depth.
Before I start looking for the best snows I wondering if I should also consider downsizing, which also would include the wheels?
Old 11-27-2016, 11:54 PM
xc1097's Avatar
i run Blizzak LM-60 235/55/17 on stock wheels during winter and Potenza S-04 255/45/18 during summer.
i believe they are now discontinued in that size tho.
here in Boston, i've had these sets since 2013 and survived winter of 2014-15 with 100+ inches of snow.
i even towed friend's gs350awd in a lot stuck in snow with my RL on snows.
you can tell the car doesn't handle well as the summers and load noise/humming is noticeably louder on winters.
i don't think there is direct replacement for lm-60 at the moment but you could try using lm-80evo which is light truck/suv tire or go with dunlops.
hope that helps.
Old 11-27-2016, 11:56 PM
xc1097's Avatar
some has set for sale on ebay
http://www.ebay.com/itm/4-New-Bridge...-/142192060612
Old 11-28-2016, 12:14 AM
projektvertx's Avatar
Can't go wrong with Blizzaks or X-Ice's. Test prove the Blizzaks are superior snow performers though. I never go a winter without snow tires.
Old 11-28-2016, 09:14 AM
hope that helps.
235/55/17 on stock wheels? My wheels are 18". Did you buy a 17" set too?
Old 11-28-2016, 10:00 AM
Fk no!TheyldstroyEvrthing
RL09's Avatar
I think you need the same size wheel for a given tire size.
And it can't get rougher than the arctic north here. Your 18 will do fine on this car, it's 4100 lbs! I got dunlop winter maxx on them and the handling is the best i've had.
There's an entire tire section btw for further info, look on top of page.
Old 11-28-2016, 10:28 AM
Thanks, I browsed the tire section here but couldn't find anything pertaining to why/if you need to go to a smaller diameter
Old 11-28-2016, 10:39 AM
RL09's Avatar
https://acurazine.com/forums/2g-rl-t...stions-943333/
Old 11-28-2016, 11:36 AM
thisaznboi88's Avatar
Ideally you want to run narrower tires. The reason for that is that the contact patch is smaller and you get more load/pressure on that patches that actually grip the road. Check out Discounttiredirect website and see what size they recommend for your 18in wheels. Or if you want it's a good time to buy a second set of rims/tires for just the snow.
SHAWD + snow tires = WIN
The following 2 users liked this post by thisaznboi88:
oo7spy (11-28-2016), teh CL (11-28-2016)
Old 11-28-2016, 05:37 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
Diameter stays the same. Width should decrease.
teh CL (11-28-2016)
Old 12-01-2016, 10:14 AM
phishfood's Avatar
I bought Hakkapellita 8 tires for my RL
From tiresbyweb.com
I do have 17" wheels but you can check there for 18" in your size. They do vary wildly and I found, for example, a 225 might cost 20% less than a 235
I would look at your wheel size (for example, 16"x6.5", though yours if 18"x???") and get a list of "perfect fit" and "will fit" so you can shop about.
The 8's are great, and studded, and very loud on bare pavement. I researched a lot and went with studs as I have some gnarly uphill/downhill areas and ice. If not for that I would have done Michelin X-ice XI3 or Happapeliita R2 treads.
Same thing find some prospective 17" wheels, get rid width, look up what accepted sizes are. I try to stay away from the margins and only mildy move one step from the "perfect fit" size.
The big thing is a set of wheels becomes cheap if you plan on keeping the car XX years versus constantly mounting, unmounting, and balancing tires twice a year. And 17" winter tires are cheaper than 18". Keep in mind this also means you need four more tire pressure monitor stems.
If yes you're buying wheels I would totally downsize to 17"
Old 12-04-2016, 08:43 AM
oo7spy's Avatar
RL wheel width is 8.5" if I remember correctly. His are 18" because it's a KB2.
RYANJR1
04-06-2017 03:43 AM
Catia
1G RDX (2007-2012)
03-23-2017 05:43 PM
shurik74
02-08-2017 06:27 PM
smurfhunter
10-05-2016 03:11 PM
RYANJR1
02-02-2016 08:32 AM
Quick Reply: Snow tires?
