Show us your aftermarket and OEM wheels on your RL
#362
Daze05RL, setup looks good. Any pics looking down the dose from the front or rear? I'd like to see how flush the fitment is in the rear. I was under the impression 10 was too wide but it looks about perfect.
Are you lowered at all?
The following 2 users liked this post by tkosho24v:
Ratheruneeq (09-10-2015),
SVTruong (07-16-2015)
#364
tkosho24v, super clean. I was looking at your car for inspiration when building mine. Too bad you can't find Mugen parts over here. Those flares are nice. =)
My KB1
My KB1
The following 4 users liked this post by SVTruong:
#365
Well done!
The following 3 users liked this post by NathanJax:
#369
Nothing special on the build list.
05 RL A-Spec
- All stock engine/performance
- H&R Springs (Cut)
- 20" Niche Targa wheels
- 255/35/20 rubber
- Lip guard
- Sunroof Visor (I may remove this)
More photos to come
05 RL A-Spec
- H&R Springs (Cut)
- 255/35/20 rubber
- Lip guard
More photos to come
Ratheruneeq (08-06-2015)
#370
You cut H&Rs?!? Those are low to begin with. What would you estimate your drop at?
#372
They are kind of low. The drop for the rear is ok but the front was just too high for my liking. I had a performance shop cut them to make it look even as I was aiming for a 1 finger drop all 4 corners. My buddy has an RL with the stock H&R springs and I wasn't thrilled with the look. He actually suggested cutting it and I read some threads about it. The ride is not as bad as I expected as the spring rate probably didn't change too significantly.
It does rub when I hit a hard bump though.
#374
Make a new thread in the photo gallery.
#376
Thanks bro.....
Thanks bro... funny thing is that I got the inspiration to build my car from viewing another member of this forum and this bunny hopping will go on and on and I am sure that your car will inspire others to follow.
MSW 6SP (07-19-2015)
#379
Yes, H&R springs on stock or Aspec struts.
#381
I know what h&r springs are, had them on my legend. Someone was just trying to tell me it was ok to use them on stock (non aspec) struts, pretty sure theyd blow in not no time from bottoming out.
#382
My H&R springs on base (non ASpec) suspension don't bottom out and I've had them a while. Everything rides good and smooth. There are PLENTY of people on this forum that have done the same thing
The following 2 users liked this post by NathanJax:
oo7spy (08-08-2015),
Ratheruneeq (08-07-2015)
#383
Interesting..... how much of a drop are you getting and what size wheels are you running? Photos? Also has anyone replaced suspension outside of coilovers? Its pretty sickening that only KYBs are available on a fairly current model..... Im wasnt expecting a lot but only KYB? Makes no sense lol i gotta try and get Koni on the band wagon
#385
#390
Took them off today...
Ruff R2
20x8.5 +30 Nitto 235/35/20
20x10 +42 Nitto 275/30/20
Attachment 102683
Attachment 102684
Attachment 102685
Ruff R2
Attachment 102683
Attachment 102684
Attachment 102685
Supreme (09-17-2015)
#394
It's ironic US modders turn Acuras into Hondas and Japanese modders turn Hondas into Acuras. Cars look nice.
#396
I guess I'll throw mine up here, even though it's not lowered yet.
Zedd SLM
Fronts are 19x8.5 et35, 8mm spacer, et27 final offset.
Rears are 19x9.5 et30.
245/40/19 all around.
Probably going to a 6.5mm front spacer to bring them in a bit more, and maybe a narrower tire...not sure yet. Depends on how low it ends up.
Zedd SLM
#397
You should really match your tire diameters all around. You can burn up your transfer case otherwise.
#399
There is an old rule of thumb for wheel with a lip. No lip: OEM + 2". With lip: OEM + 3". The lip (especially on that style wheel) creates an illusion that the wheel is smaller. Couple in the stock suspension, and they look small.
