Ignition key cylinder replacement
6th Gear
Hello
Hoping for any info on replacing ignition key cylinder in ignition assembly. Would like to use original key in new ignition assembly on 05 rl. Any comments would be appreciated?
Check the service manual?
6th Gear
6th Gear
thank you for the suggestion. I had that work done. I now have multiple keys now. Ignition is no longer same as door, ski pass through and glove box. Just bummed out about it.
maharajamd
10-20-2016 04:10 PM
Allison Cronin
1G TSX Problems & Fixes
10-17-2016 09:55 AM
