Bypass "Please check disk" error?
Greetings!
I get the dreaded error listed above in my '05 RL. I've done all the troubleshooting I can find throughout acurazine.com (including removing the disk drive and cleaning the laser). What I haven't found is if there is a way to bypass this issue to have use over the screen for other things, e.g. radio.
I live in PA but due to the error I'm stuck on Pacific standard time. This is annoying but I'd deal with this and the lack of nav if I could get other use out of the screen and not have the error showing 24/7. I hate to spend the $300-400 to send the drive in for repair. Any thoughts, ideas, or am I SOL?
Thanks for any advice!
Buy used one?
Are you sure it's not the disc? If it's not, but a used drive on eBay.
I have a spare 2005 Navi that I don't need it. Let me know if u want it. just send me a message.
Greetings!
In the meantime I disconnected the battery and pulled the unit one last time. Blew a nice bit of air through it and again went at the lens with some rubbing alcohol and still no luck.
In light of this, and before I buy another, is there anything else i need to troubleshoot, or is this a symptom of only the drive?
Thank you all for your advice!
