Wheel Locks
Old 06-25-2015, 09:01 AM
abanytime's Avatar
Wheel Locks
What's everyone using? factory? Aftermarket?
- Andy
Old 06-25-2015, 09:04 AM
Received 16,260 Likes on 11,971 Posts
pretty simple; have factory wheels? use factory locks!
aftermarket wheels? use aftermarket locks!
because of the different shaped lugs; you will need to use a lug that corresponds to your wheels.
Stock wheels have a ball seated lug nut
after market wheels use a cone shaped lug nut.
vetdude (06-15-2017)
Old 06-25-2015, 09:45 AM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
Do you have OEM rims or aftermarket? When I had OEM wheel locks with OEM rims, every place I went for tire maint had their own universal wheel lock key and didn't need mine. Only the laziest and dumbest crackhead thief would be slowed down by OEM wheel lock. I have aftermarket rims on all three Acura's now and went with Gorilla wheel locks that has an unique lug key for each vehicle ($14 on Amazon). I needed the conical type for aftermarket RonJon rims and OEM rims need ball type lugs (not sure if the newer +13 Acura's still have ball type lugs).
I kept my OEM rims as full size spares for all three vehicles and I had to keep the OEM lugs in the vehicles because they are not interchangeable with the aftermarket rims conical lugs. I actually have two different types rim locks on my rims. $14 for wheel locks is a lot cheaper than $2400 -$3000 for new tires/rims.
Old 06-25-2015, 09:55 AM
^FYI; I can take off an aftermarket lock without the key.
it should be used as a deterrent. the longer it takes for a thief to break into, the more chances that they'll give up.
Old 06-25-2015, 10:28 AM
rosen39's Avatar
After watching the many videos online, it is very easy to remove those wheel locks.
justnspace (06-25-2015)
Old 06-25-2015, 10:35 AM
^aftermarket is a little harder, but still do-able using the same method.
I had lost my key to my aftermarket lugs and all i did was place a slightly smaller socket over it, hammer it on....then used the breaker bar to loosen it.
Voila!
throw away socket and lock when done.
Old 06-26-2015, 07:50 AM
mrgold35
mrgold35's Avatar
The best way to go is maybe layers of security like:
- not putting the vehicle in a situation where the tires/rims can be stolen (clean out the garage of junk and use it for your car)
- add wheel lock(s), I have two different types
- add a very loud 2-way alarm that will also alarm your remote if triggered (have this on my son's TSX since he has to park outside and at H.S.)
Still no guarantee against a determined thief;but, it might slow them down enough to move on to the next one.
justnspace (06-26-2015)
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
ahsm
09-09-2015 08:35 AM
braveheart
09-07-2015 08:12 AM
Quick Reply: Wheel Locks
