Question on Pirelli Scorpion Verde Plus
Old 02-01-2017, 10:41 AM
D Leopoldi's Avatar
I have an acura rdx 2013 AWD and at 35K the stock tires needed to be replaced. I replaced them with Pirelli Scorpion Plus Verde. Took the car to the dealer for an oil change and got back the inspection and notice the tires at 4/32 on their chart. I went back to when I purchased the tire and have the brochure that says tire is garanteed 65k miles. I have 72k miles on the car so doubt going to be able to get 35k more miles on 2/32 thread. I notice to file a claim I need to have filled out this sheet that shows I rotated the tires at every 5-7k miles. I would need to work through one of their authorized dealers to file this warranty claim. I am in Connecticut. Aynone know anyone with any experience with Pirelli on this warranty? I think I will be able to get through the winter but by next fall would like to change the tires out for winter.
Old 02-02-2017, 12:16 PM
D Leopoldi's Avatar
Bump Anyone?
Old 02-02-2017, 12:19 PM
Received 16,260 Likes on 11,971 Posts
I read yesterday. I couldnt advise on warranty other than, do the paper work and get it done....
but I did have one question; how sure are you that the acura tech measured the tire right?
and do you rotate and balance them regularly?
okay, that was 2 questions
Old 02-02-2017, 12:45 PM
D Leopoldi's Avatar
Every 15k miles I rotate and balance.
The paper work would need to be done at the pirelli dealer every 3-4k miles which I didn't do just had the dealer rotate when the maintenance schedule advised.
Maybe you are right the tech didn't read the thread right, because 10k miles ago I believe i was read at 7/32, so doubt i burned 3/32 in 10k miles.
Old 02-02-2017, 12:46 PM
double check the tread yourself.
Old 02-02-2017, 01:08 PM
D Leopoldi's Avatar
I am 4/32 at the top of washingtons head. How do I know if I am 6/32
Old 02-02-2017, 01:10 PM
Originally Posted by google
How do you measure tire tread depth?
Use a tread depth gauge, or if you don't happen to have one of those laying around, try the “penny test.” Insert a penny into the tire tread grooves with Lincoln's head facing down. If you can see the top of Lincoln's head, your tires are at 2/32nds of an inch or less of remaining tread. You need new tires immediately!
hmmm. so it would seem as the tech measured correctly.
Old 02-02-2017, 01:38 PM
D Leopoldi's Avatar
I am asking If the quarter is at the top of the head I am 4/32 right?
Old 02-02-2017, 01:39 PM
use a penny!
Old 02-02-2017, 07:18 PM
D Leopoldi's Avatar
Tech was right 4/32 I can't believe it. Should I try to find a Pirelli dealer and get them to warranty the tires for me. I didn't fill out the tire rotation sheet sheet. Think a dealer will help me.
Old 02-07-2017, 01:35 PM
D Leopoldi's Avatar
Think I can get someone to take me on to try to get me some warranty? I did move recently and can show the tires were ordered to another state and installed.
Think a tire shop will take a shot and help me get something for them.
Tire rack I can get the pirelli scoprion verde for 740 installed. Think someone can beat that?
Old 02-07-2017, 01:40 PM
Received 8,575 Likes on 6,626 Posts
Tire warranties like all other warranties have conditions:
Here's directly from Pirelli's website:https://www.pirelli.com/tires/en-us/.../tire-warranty
The PTNA Treadwear Mileage Warranty Conditions:
- You are the original purchaser of the tires and have a copy of the original invoice showing the application mileage.
- You are the owner of the vehicle on which the tires were originally installed.
- The tires are replacement tires (PTNA Treadwear Mileage Warranty does not apply to Original Equipment tires).
- You have had the tires roatated every 5,000 to 7,000 miles.
- The tires are worn evenly across the tread, down to the treadwear indicator (2/32'') at which time they are considered to be 100% worn out. There cannot be more than 2/32" tread depth difference across the tire.
- Your servicing Pirelli Dealer has completed the Tire Rotation Record.
- PTNA Mileage Warranty does not apply to Original Equipment fitments.
- Passenger and P-Metric Light Truck tires are not covered for mileage when used on commercial vehicles or in commercial applications.
- Mileage warranty does not apply to Euro-metric tires purchased before July 1, 2011.
- For vehicles equipped with staggered size fitments (different tire sizes front and rear), the mileage warranty for the rear tires will be 50% of the stated mileage warranty for that line.
- Run Flat tires will have a mileage warranty of 50% of the stated mileage warranty for that line, not to exceed 30,000 miles, whichever is lower.
Old 02-07-2017, 01:51 PM
D Leopoldi's Avatar
Hmm wonder if I can get a dealer to fill it out for me that will sell me new tires.
Anyway, even if I did local dealers are more expensive than tire rack so pretty much will break even with ordering again from tire rack and with tirerack won't have to deal with the hassle of the paper work.
How many miles you think I can drive on 4/32 until I go to 2/32?
Old 02-07-2017, 01:55 PM
probably about 3,450 miles
Old 09-11-2017, 12:03 PM
tegraphile's Avatar
I was looking into the Verde Plus for my 2014 FWD, but seems like the two issues are increased road noise after 10K miles and short tread life. That fact that Tire Rack is starting to discount a lot of the tires also makes me think the reviews have more weight. I also was looking into Conti ProContact as an alternative. It's a touring tire, with a 80-90K tread rating.
Any follow ups on the the Verde Plus long term?
Old 11-02-2017, 05:25 AM
mattski's Avatar
I have had these for 2 years and almost 20k and they have been great. Little wear and very quiet still. I am a “spirited” driver, so not as sticky as I like, but I hope to get at least 50k out of these.
Old 11-02-2017, 06:23 AM
D Leopoldi's Avatar
First off the tire shop that told me they were low they were not. I am actually just retiring these after 55k miles.
Going to buy another set. $700 mount, balance and alignment cannot go wrong.
My only complaint and not sure if it is due to car and some to all the kind of tire these are is in ice and snow not the best . They are not horrible but not great
Old 11-06-2017, 04:20 AM
mattski's Avatar
good to hear you got 55k out a set
I only run mine for three seasons, so no experience with snow and ice. Dedicated winter tires and rims are the way to go IMHO
Old 11-11-2017, 07:41 PM
Scott in AZ's Avatar
I’ve got those P-Scorpion Verde tires as the replacement tires on my 2010 AWD MDX. They were installed at 45,700 Miles for $744 out the door with new TPMS. I have almost 73,000 Miles now on the MDX so only 28,000 Mile. I can’t get to my SUV to check exact tread depth right now, but probably will need to change them in another 5,000 to 8,000 Miles. I was expecting more mileage than this, but probably won’t press for a warranty replacement. I’ve found them to be pretty good tires, but yes, in my layman’s opinion, they wear fast.
I read this thread as homework to find good replacement tires for my wife’s 2014 RDX FWD. What is the general consensus on the best replacement tire? I probably would not use the P-Scorpion Verde again. Will probably go with Michelin.
Old 01-29-2018, 04:25 PM
tegraphile's Avatar
Tire Rack has an a great deal on the Scorpio Verde All Season Plus @ $115.36 a tire
Add 3 Plenti points per dollar (which translates to $13.84 in Exxon/Mobil gas) and 2% cash back on my MasterCard on top of a $70 Pirelli Mastercard mail-in rebate. I think it was too good to pass up and today was the last day of the rebate.
Will report initial impressions in the coming weeks
