BC racing coilovers
Old 04-20-2014, 08:47 PM
3rd Gear
ccsmoker's Avatar
BC racing coilovers
I was told by a vendor that 07-12 would fit on the 2013 RDX. does anyone know if there is any truth in his claim?? I am in need of a set to finish off my RDX. my RDX is sitting on a set of 20x10 rims and the gap is just killing me...
Old 04-20-2014, 08:55 PM
Received 16,260 Likes on 11,971 Posts
compare the top hats between the years.
then compare the bottom where it bolts into the fork.
if the same between the years, the BC coils will work.
and BC racing is something special.
they are one of the only coilover companies that provide a full threaded bodies.
this allows you to retain stock like qualities.
they ALSO let you customize spring rates.
I suggest you go a little bit stiffer.
Old 04-23-2014, 10:05 AM
OG
Type X's Avatar
Unsure "BUT" a member here has 2012 shocks on his 2013 to fix the rear "thud" we all have so i'd check into those rear sound complaint threads
Old 04-28-2014, 09:21 PM
hand-filer's Avatar
The rear shocks have the same overall dimensions. As far as I know coilovers are available for the front only for the older RDX.
Old 05-01-2014, 01:13 PM
WTF?
bluecarbonfiber's Avatar
if its true that the 2013-14 have say suspension as the previous years Heeltoe auto sells the eibach lowering springs so there is a second option to lowering your vehicle..
Old 08-09-2014, 10:49 AM
jimjimmyjim's Avatar
Anyone aware of an update regarding lowering springs available for the 2013 RDX?
I have added a new set of wheels (20s) and the gap is bad. Looking for a sport drop only (1 to 1.5 inch).
Old 04-29-2015, 08:51 AM
3rd Gear
momoboi's Avatar
2015 Acura rdx
So did anyone figure out if there's any coilovers out there that would fit a 2013-2015 Acura Rdx????
Old 05-01-2015, 07:17 AM
basilisk4's Avatar
I'd also be interested in knowing whether there are any suspension upgrades (e.g., coilovers) that will properly work on a 2nd gen RDX...
Old 07-02-2015, 08:51 PM
Needs a 930
BeezleTL85's Avatar
+100
I'd love to get our 2nd gen closer to the ground and eliminate some of that roll
Old 07-03-2015, 09:00 PM
basilisk4's Avatar
Originally Posted by BeezleTL85
+100
Anyone??
Old 09-14-2015, 07:30 AM
3rd Gear
momoboi's Avatar
Update anyone????
Old 11-07-2017, 04:21 PM
+100
What a fucking baller!
Old 01-19-2018, 10:53 AM
The6ix's Avatar
I started a thread on cross over parts from other Honda/Acura models for the Gen 2 RDX in terms of performance parts and lowering the RDX. I believe the Odyssey and for CRV lowering springs will work for the gen 2 RDX.
Link below.
https://acurazine.com/forums/2g-rdx-...e-list-966299/
MrHeeltoe
20
02-23-2023 01:54 PM
F-C
Motorsports News
33
08-22-2018 09:53 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
Quick Reply: BC racing coilovers
