Rear hatch hitting garage door
I read the solution on a Mdx forum and it actually works.
Pool noodle or pipe insulation on the last garage door ridge for the peace of mind of car owners
well done OP! Very ingenious solution! Innovation at its finest
, but the vertical box-frame pieces are something I've not seen before. That's probably what adds to the problem that you're seeing. My garage door is similar to yours, and would hit the same if I had vertical supports. Is that door like hurricane-proof or something?
andy
Wow - that is quite the structure on your garage door. Most I've seen have the horizontal pieces that you've protected with the pool noodle
andy
andy
The vertical supports acts as a frame to hold the thin piece of sheet metal. This garage door is not insulated and that's why you see the metal supports. If you have an insulated garage door, the metal support will be covered by another piece of sheet metal and insulation will be sprayed in between..
We have a Volvo C70 as well as the new wagon...switching sides from time to time and even backing in as needed. The little 'Stop sign' I bought for DW has taken a beating on the occasions that she is very tired when she gets home...or not paying attention...or mad at something...or just listening to a REALLY loud song on the radio. She could make mincemeat of those bumpers!!!
andy
We don't have the cross piece on our insulated door. The part that would dig a hole in the hatch is the foot/hand 'handle' that facilitates opening/closing manually. It is bare metal(but I might still put something over it). I actually keep a noodle section IN the vehicle to cushion between the hatch and the garage door.(Doesn't mean EVERYbody will use it, however )
Another option might be the soft foam pipe insulation...in fact, I have some left over from another project. It's a smaller diameter and black(with double-stick tape for convenient installation of the insulation ). Not as much cushion; but should do the job.
the only time I've had garage door interference problems with a hatch was with my old Tahoe, where the hatch would hit the door, especially where the wiper was. I ended up getting a foam square from home depot (I think it was used for padding under carpet or rugs) and I used contact cement and put it on the section of door that hit. Since you never park in exactly the same spot, I wanted to make sure it was big enough to compensate for different locations - I think it was like 2x2 feet or something. Anyway it didn't look bad and protected the car (and the door). You could probably use anything that would act as padding......
andy
andy
Summer is Coming
andy
andy
As soon as I saw those pics I knew this was a garage door in Houston. namely on the south side, I have the same reinforcement. It is for hurricane protection. It gives the garage door the strength it needs to stand up to 120 mph winds. Mine were tested during Ike up to 100 mph and came through without impact. They do add size to the door but worth it.
Summer is Coming
Also, where did you get those bumpers? Are they glued to the floor?
Yup, I have my plywood too. Survived Ike and Rita before that, but Rita never really hit here. BTW, do yourself a favor, get some exterior latex paint and paint them. That way when they get wet they will not warp and you can use them over again.
Bumpers stick to the floor with double sided tape. Bought them on Amazon.
Rocket_man (08-09-2015)
The garage doors are generally the weak link when it comes to hurricanes. Once the garage doors go, the whole house goes as the wind enters the garage, has no place to go and goes through the rest of the house.
If the garage doors stay intact then the house has a good chance of surviving - assuming that the roof is built to specs.
It is too bad Acura didn't make the power liftgate adjustable. Both a VW Touareg and Audi Q7 I had in the past could be adjusted so they didn't hit objects when quarters are tight. I was surprised to find the RDX didn't have this feature as the Hyundai Tuscon Limited I looked did....
X2. Our rear hatch hits also...extremely annoying for a new car to have this happen.
especially after tossing recent notes about how the RAV4 was height adjustable.
can shorter struts be put in to lower the height?...or are there limits set for the travel and sensors?
rockyboy
12-06-2022 02:29 PM
09-04-2015 08:03 AM
