Keyfob memory - 2017 RDX
Old 03-16-2017, 08:35 PM
JTL__ACURA's Avatar
Does anyone else have a problem when they open the door it doesn't change to the key fob side mirror setting? Also when you start the engine it doesn't change to the side mirror setting?
Old 06-15-2017, 10:26 AM
vetdude's Avatar
Not on ours. Sounds weird. Did you adjust your mirrors to where you want them, then press SET, then press 1 or 2 on the door panel to save the setting?
Old 06-24-2017, 07:05 PM
YeuEmMaiMai's Avatar
is the mirror control in the set position for the left or right mirror, the older acuras would not move the mirrors unless the knob was in the center position.
