2017 RDX passenger side window glass shatters
Old 09-28-2016, 08:06 AM
9th Gear
NorthAcuraRDX's Avatar
I just got my RDX 2 weeks ago, and recently I noticed that when my car hit some pit on highway or run on poor street roads, it sounds like passenger side window is vibrating and shattering, is that abnormal, as I expected Acura to be much better than this.
Old 09-28-2016, 08:07 AM
Received 8,568 Likes on 6,621 Posts
Shatters...? So the window is gone?
Old 09-28-2016, 08:11 AM
9th Gear
rattles, lol,
Rattles aren't normal. Your car should be under warranty so take it in!
Old 09-28-2016, 08:15 AM
9th Gear
Even it only happens when hits the pits or on poor roads?
Received 16,260 Likes on 11,971 Posts
at first, I was like "What did you hit!?" lol
but good to hear that its only rattling and not shattered
Old 09-28-2016, 08:17 AM
can you record a clip of this happening
Old 09-28-2016, 08:19 AM
9th Gear
lol, typo first and picked a wrong spelling suggestion.
justnspace (09-28-2016)
Old 09-28-2016, 08:21 AM
9th Gear
well, it's not always there, and sounds more like a bee, buzzzzzzzz, when it rattles.
still can't be normal
Old 09-28-2016, 08:23 AM
sounds like components rubbing against each other.
you can either;
A) take it in to dealer to see if they have a TSB or if they've come across this issue before...
or
B) take the door panel off and physically check yourself to see if any metal on metal action is going on..
I would choose B.
on a brand new car, i would pick A
9th Gear
cool, thx, i'm gonna bring it back to dealer. It's annoying, and a little bit disappointing.
Old 09-28-2016, 08:25 AM
True....
But I like doing that kinda stuff.
super easy to pull the door panel off, only like 4 screws.
is option A) worth my time? will they even find it?
with option B) would I even find it???
or solution C) turn up the RADIO!!!!!!!!
Old 09-28-2016, 08:31 AM
9th Gear
True....
Well, I'm not even quite sure if it's coming from the door, it sounds like the top corner of the glass is shaking when there's pits on the road.
Old 09-29-2016, 05:25 PM
SiliconFox's Avatar
If your window is open even slightly then the rattle is normal operation. Was the same in my previous car (Toyota rav4). But if your window is closed and you still get the rattle then its not normal. I doubt Acura techs will find it, and they will leave it in worse shape if they do try.
Old 10-13-2016, 05:03 AM
YeuEmMaiMai's Avatar
even if the window is open it should not rattle. I would guess that one of the track bushings is missing or prematurely worn... I have a Subaru with a frameless window design and it NEVER rattles when the window is up down or partially down even after 106K miles. the Window on the Acura sits in a frame and therefore should not move or rattle for that matter even over the most severe bumps
Old 02-01-2023, 04:34 PM
drekman's Avatar
Add me to the list of affected cars...2020 A-Spec and window shattered when closing driver door... I tuck taped the window to keep the cold out and wouldn't you know it, my dealer (North Toronto Acura) is moving into the Honda dealer down the road so there is no one there to help right now.
Has anyone in Toronto managed to get it replaced under warranty (mine expires in Aug of this year)??? If so, what dealership?
justinjsw
11-07-2023 07:42 AM
EE4Life
09-01-2023 11:05 AM
TSX69
09-06-2016 04:23 AM
EE4Life
06-27-2016 06:19 PM
vito_ip14
06-13-2016 04:29 PM
Quick Reply: 2017 RDX passenger side window glass shatters
