Oil filter substitute
Using WIX 57536 oil filters for my 2013 RDX AWD. Have a few leftover WIX 51334 from my Acura TL. Would like to use them on my RDX. They appear to be same in every way exception of the burst pressure. WIX 57536 has 363 psi burst pressure while 51334 280 psi. Anyone know if it is OK to use the 51334 on RDX with 280 pis burst pressure?
What's the burst pressure on an OE Honda filter?
So you actually think that an RDX has higher pressure than a TL? If WIX is making a filter that is so close to the edge that it supports a TL but not an RDX, then that's definitely not wix-like. The OEM honda filters are made by Fram these days, and I'd guess that it has lower burst pressure than anything WIX will make. I can't believe there's a risk......
rcs86
08-02-2016 06:52 PM
