Transmission service - Page 2 - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 04-09-2016, 10:05 PM   #41
Registered Member
Quote:
Originally Posted by Dorsey View Post
Just changed the transmission fluid on my 2013 with 26,200 miles and had same experience - measured 4.2 quarts that came out. Stupidly put 4.2 qts back in and it was way overfilled. Drained almost a quart out and good to go. BTW - getting an accurate fill level measurement on the RDX is a real trip. In addition to Acura's ritual of getting it hot, running it through the gears and then making the measurement at 60 to 90 seconds after turning off the engine, the dipstick is hard to get to and hard to read with new fluid.
The rule of thumb of drain-and-refill ATF is that you refill exact how much is drained out. You are underfill the ATF. You saw overfill because you did not measure the ATF level in the way which can be found in owner's manual.
CrimsonElan is offline   Reply With Quote
Old 06-21-2016, 04:01 PM   #42
Registered Member
bvogel7475's Avatar
Just wanted to add that you should always use the Honda Trans fluid for all of your Transmission fluid changes. Have heard nightmare stories of people thinking they could try another brand and end up wrecking their transmission. Crimson's comment about the Trans Fluid amount is right on point. I always drain my fluid into a clear bottle and mark where the level it filled to. Then I pour out the old fluid for recycling and pour the new fluid into the clear bottle up to the mark and fill it with that bottle. You should drive the car or at least run through all the gears before you check the trans fluid level and it needs to circulate to get the correct reading. This is all a very easy process that the dealer typically charges a lot for.
bvogel7475 is offline   Reply With Quote
Old 01-21-2017, 04:13 PM   #43
Registered Member
Joe Las Vegas's Avatar
I just changed mine, of course it was overfilled (damn dealer), 4 qts came out, put 3.3 in and it was low, put .2 more, total of 3.5 qts, still a bit low, will drive around good then check again later.
Joe Las Vegas is offline   Reply With Quote
Old 01-21-2017, 04:22 PM   #44
Registered Member
Quote:
He did check the fluid level the way the manual says. Rule of thumb is, the dealer will always overfill, so don't put in the amount that came out, 3.3 is supposed to go in after draining, try that first.
Old 01-22-2017, 10:50 AM   #45
Registered Member
Drove a while, checked again, it needed 3.8 qts to gets past the low mark, might need .1 qt to get close to the high mark. I took out 4 qts and it was slightly above the high mark before I changed the fluid, so much for the manual caliing for 3.3 qts��
Old 01-22-2017, 05:20 PM   #46
Registered Member
Drove a while again, still low, just forget this POS manual that says 3.3 qts, just put in 4 qts and be done with it. Good for me anyway, keeps it simple, I bought a case of 12 qts for $81.25, now I can do 3 fluid changes.
The Following User Says Thank You to Joe Las Vegas For This Useful Post:
Skidoor (01-22-2017)
Old 01-24-2017, 01:16 AM   #47
Registered Member
So 4 qt drained out and you put 4 qt back in, right?
Old 01-24-2017, 03:23 AM   #48
Registered Member
Yes, but when I checked before changing the fluid it was above the max line, I'll check again soon when hot. Still, I assumed it was way overfilled because the manual says 3.3, and then 4 qts came out, not my fault if the manual is wrong. Dealers piss me off anyway, the very often overfill, that's why I do all the fluid changes myself.
Old 03-08-2017, 03:24 PM   #49
Registered Member
V6X6's Avatar
I'm jealous of that funnel dc5k20z1. Where did you get it?
V6X6 is offline   Reply With Quote
Old 03-08-2017, 03:51 PM   #50
Quote:
I put "transmission funnel" into amazon and look at what I found
crazy.. huh?
Amazon Amazon
thoiboi is offline   Reply With Quote
Old 03-15-2017, 09:10 AM   #51
Registered Member
V6X6's Avatar
Thanks, I have one on the way now.
Thread Thread Starter Forum Replies Last Post
Ignorant buyers not understanding VCM / complaining about transmission joflewbyu2 Fifth Generation TLX (2015+) 139 10-08-2015 11:16 AM
2012 Acura TL SH-AWD Advance shifting mellsonnj Fourth Generation TL (2009-2014) 3 09-24-2015 04:42 PM
Loaner Car Observations TL14 Fifth Generation TLX (2015+) 2 09-24-2015 04:37 PM
What to watch out for? tristann616 1G & 2G MDX Discussion (2001-2013) 2 09-22-2015 11:40 PM
Access to adding Transmission fluid ROSSARONIE Third Generation TL (2004-2008) 6 09-22-2015 11:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
