High mount brake light pulsar
7th Gear
Hello All. I new to the forum and just purchased a 2017 RDX. I would like to install a pulsar for the high mount brake light that will flash the light then remain on. Can anyone tell me the wire colors to the high mount brake light and is there an easy way to access the wiring or the light itself. Thanks in advance for your assistance.
7th Gear
Wire Colors to Hi-mount brake light
I found the easy way to access the wires was to remove the third brake light. Found green (positive) and black (negative) wires connected to the third brake light. The wires are relatively short, but I was able to cut the wires and solder in the pulsar. Works perfect. Apply brakes and third brake light strobes fast 4 times, then slow flash 4 times then on steady.
