Key Fob Help - AcuraZine - Acura Enthusiast Community
Key Fob Help
Thread Tools Search this Thread
Old 05-28-2015, 09:47 PM   #1
New Member
Key Fob Help
Hi everyone i recently machine washed one of my key set, which had my Acura key fob on it, yes stupidity of mine. Currently the key kinda works, when i mean kinda half of the functions work. None of the buttons on the fob works but the vehicle still recognizes the key in its proximity. When inside a hand full times the car will start.
I open the actual key fob and it doesnt seem like and rust has formed. When inserting a battery the red led turns on for a couple seconds then turns off.
Any recommendations they get this back up and running? I know with some other brands you can add a fob if you have two fobs already. Can you do that with Acrua? How much would a different fob? Does i have to be new?d
I havent called the dealership but im already thinking it will be up the arse.
ipodnag is offline   Reply With Quote
Old 05-29-2015, 06:23 PM   #2
ceb
Registered Member
A few things you can try:
Dry out the fob entirely by removing the battery, wrapping it in a Kleenex and putting it into a Ziploc bag with uncooked rice. Leave it for a few days.
Once dry, use a new battery and see if it works. If not, then you'll most likely need a new key.
You cannot use a "used" fob. It has to be new and will need to be programmed by the dealer.
Yes, it will be expensive, let's hope that the rice and new battery work.
ceb is offline   Reply With Quote
Old 07-20-2015, 09:48 PM   #3
Registered Member
Well, if you can remove all traces of water, may be you can bring it to the dealership and have them replace it under warranty.
RSX_Takashi is offline   Reply With Quote
Old 07-21-2015, 03:08 PM   #4
ceb
Registered Member
Quote:
First, that would be warranty fraud. Secondly, if you removed all traces of water then the fob would work. If water damages electronics then there always is evidence.
Old 12-21-2015, 01:04 AM   #5
New Member
Hi Guys.. I'm new here.. Just picked up a 2016 RDX. Our fob keeps beeping even though we are in the house. We checked to make sure all doors and shut and locked. What am I missing?! Thanks!
Phillywood is offline   Reply With Quote
Old 12-22-2015, 04:36 AM   #6
Registered Member
Desert Ridge's Avatar
Quote:
I've never, ever heard a noise come out of my key fob.
Desert Ridge is offline   Reply With Quote
Old 07-08-2016, 11:51 PM   #7
Registered Member
i haven't either...
Nitefall is offline   Reply With Quote
Old 07-30-2016, 01:23 PM   #8
Registered Member
Al Dente's Avatar
The fob or the car keeps beeping? If it's the car, maybe you left the engine on.
Al Dente is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Key FOB Protector datadr Fifth Generation TLX (2015+) 24 03-23-2016 02:39 PM
Tapping in map light from side mirror (puddle light) soupi 2G TSX Audio, Bluetooth, Electronics & Navigation 14 11-15-2015 12:15 PM
'07-'08 Key fob rehab eastcoastguy Third Generation TL (2004-2008) 25 10-29-2015 04:00 PM
Beep Acknowledge intermittently working DementiaPhuro 3G TL Problems & Fixes 1 09-29-2015 06:31 PM
WTB: 01 cl type s auto ecu and ignition malvothegreat Car Parts for Sale 0 09-29-2015 01:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
