Are the fluid change maintenance reminders premature? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 11-30-2014, 08:15 PM   #1
Registered Member
I do my own oil changes with Mobil 1 0W20 approx. every 7500 miles or so. My B16 came up around 17K and my A123 came up around 26K. My mechanic thinks it is insane to replace transmission, transfer case and rear differential fluid before 60K and recommended that I should continue with regular oil changes, reset the maintenance reminder and not to worry about them till 60K. What do you guys think and practice?
spartan77777 is offline   Reply With Quote
Old 11-30-2014, 10:11 PM   #2
Registered Member
Say good bye to your warranty if you don't. I haven't had those maintenance issues come up yet
mdfree is offline   Reply With Quote
Old 11-30-2014, 10:19 PM   #3
Get Out Of The Left Lane!
NBP04TL4ME's Avatar
Do you do any trailer towing or regular mountainous driving? According to the owner's manual these may warrant earlier fluid changes.
NBP04TL4ME is offline   Reply With Quote
Old 12-01-2014, 08:47 AM   #4
ceb
Registered Member
Quote:
Will your mechanic cover any warranty related issues that the dealer denies?
The dealer doesn't even need to prove that the lack of maintenance caused the issue. He merely needs to show that you cannot prove that you did the maintenance.
ceb is offline   Reply With Quote
Old 12-01-2014, 09:00 AM   #5
its sooo much better to change the transmission fluid and differential fluid before the fluid wears thin and leaves you with less than ideal protection.
if you want to change it after the fluid wears down, be my guest.
justnspace is offline   Reply With Quote
Old 12-01-2014, 06:34 PM   #6
Registered Member
I agree with your mechanic that is is probably not necessary, but I would still replace them for warranty purposes.
Apexigsx is offline   Reply With Quote
Old 12-01-2014, 06:54 PM   #7
NBP04TL4ME's Avatar
Agreed, but 26K does sound kind of early.......
Old 12-02-2014, 10:25 AM   #8
Registered Member
hondu's Avatar
You need to find a new mechanic. The DW-1 fluid in your transmission is probably only good for around 15-30,000 miles, so I would say your MM is accurate. I believe a rear diff change around 15,000 miles is also typical for the RDX. I would recommend changing all of the fluids.
I would not be surprised if your tranny fluid is very black at the moment and the drain plug is full of metal shavings.
hondu is offline   Reply With Quote
Old 12-04-2014, 10:50 AM   #9
Registered Member
I went through the same thought process but decided to change the transmission oil myself when it asked for it (around 30k) just because of how easy it is. Didn't have to worry about transfer/diff change though as I'm 2WD. If you do your own engine oil changes, you can definitely handle a tranny oil change. Hardest part is routing a funnel down to the fill point as it's tucked down deep behind the radiator. If you have a 3/8" ratchet (don't even need a socket - the plug is square drive) and a long-neck funnel, you got all the tools you need.
And FWIW, the old oil was just about spotless when I changed it. It definitely didn't look or smell burned up or like it desperately needed to be changed. Granted, it's anybody's guess how much it might have broken down chemically, but contamination certainly wasn't an issue.
Scheffy is offline   Reply With Quote
Old 12-04-2014, 12:40 PM   #10
Registered Member
Quote:
If that's the case at that mileage he'd have some serious problems.
markAZ is offline   Reply With Quote
Old 12-04-2014, 05:36 PM   #11
ceb
Registered Member
...I would not be surprised if your tranny fluid is very black at the moment and the drain plug is full of metal shavings.
Quote:
Originally Posted by Scheffy View Post
...And FWIW, the old oil was just about spotless when I changed it. It definitely didn't look or smell burned up or like it desperately needed to be changed. Granted, it's anybody's guess how much it might have broken down chemically, but contamination certainly wasn't an issue.
Color is seldom an indication of fluid quality.
Oil can change color within a very short period and still be fine, while a fluid in a more closed system can look perfectly fine and no longer be able to do its job.
Manufacturers spend millions in determining the proper fluid change intervals. While it might not apply to absolutely every driver but following the required intervals will keep your warranty intact and your car running well.
Old 12-04-2014, 08:29 PM   #12
Registered Member
hondu's Avatar
Quote:
Based on the research I've done on DW-1 fluid, it is only good for around 30,000 miles. On every Honda/Acura tranny I've changed the fluid on, the very first change around 30,000 miles, the magnetic drain plug was full of metal shavings (and seen it on others as well). This is not a serious problem and very common. Why do you think Honda uses a magnetic plug? Additionally, most auto trannies experience most of their metal wear in the first 15,000 miles or so.
Personally, I would recommend a drain and fill on the RDX every 15,000 miles, instead of doing three at 30,000. The first change will help get rid of the initial metal build up, and the subsequent changes will keep the fluid fresh and protect your tranny better.
Old 12-04-2014, 08:34 PM   #13
Registered Member
hondu's Avatar
That is why the MM on the RDX is around 30,000 miles for the tranny change. The fluid is ready for it by then. While I agree, the fluid getting darker is not necessarily the main indicator, but for tranny fluid, if it is completely black fluid, versus very dark with some red tinge to it, it is a good sign it is ready for a change (at least for DW-1 that is). An even worse sign would be completely black and a "burnt" smell, which would be very bad...
Old 12-05-2014, 11:52 AM   #14
Registered Member
You should not have chunks of metal on the drain plug magnet. Some fuzz is OK and probably normal but black fluid is bad at just about any mileage. That was what I was referring to.
Old 12-05-2014, 02:36 PM   #15
Registered Member
hondu's Avatar
Who said anything about chunks? I said metal shavings. Shavings are very small/fine pieces of metal. The agglomeration looks almost "paste-like", for lack of a better description.
On my first change, there was typically a decent amount of shavings, on the second and subsequent changes, the amount of shavings dropped precipitously.
As for black fluid, I agree, and around 30,000 miles on DW-1, the fluid is most likely black.
Old 10-08-2016, 07:25 PM   #16
Registered Member
I have 31K miles on my 2015 RDX base and the tranny fluid is still very clean. Not sure to change it or wait till 50K miles.
emry is offline   Reply With Quote
Old 10-09-2016, 10:01 AM   #17
Registered Member
Brown13's Avatar
You will find it clean on the dipstick,but when You change it and put the used oil in a container, like an old gallon milk bottle,it will be look black.
Brown13 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 3G TL Problems & Fixes 50 01-19-2017 02:13 PM
CLOSED: 4G TL Going Back to Stock (coils, intake, mats, etc...) nanos Car Parts for Sale 26 11-12-2015 09:41 PM
Maintaining Transmission After Engine Swap ghuns Second Generation TL (1999-2003) 5 09-16-2015 05:26 PM
Oil Changes datadr Fifth Generation TLX (2015+) 6 09-12-2015 10:12 PM
Found an oil leak Aleax 3G TL Problems & Fixes 2 09-11-2015 12:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
