What is This?
Old 04-06-2016, 06:04 PM
dbarnhart's Avatar
What is This?
One of the frustrating things about the unavailability of of a real service manual is the inability to identify things under the hood. For example, what is this (2016 RDX Tech):
Old 04-06-2016, 08:23 PM
rosen39's Avatar
Take the cover off and send us a picture.
Either additional fuses, circuit breakers, relay or a diagnostic connector.
Look here at Wiring Harness #1
http://acura.bernardiparts.com/Acura/Parts-List.aspx
It looks like the cover is part #40 "Relay Cover"
Old 04-11-2016, 11:06 AM
dbarnhart's Avatar
I removed the cover and took the photo below. Looks like a relay. Then the next question is 'For what?'
Old 04-11-2016, 11:23 AM
markAZ's Avatar
Pull it out & see what doesn't work.
Seriously, google-ing the part number seems to indicate it's part of the A/C system, perhaps the compressor relay.
Old 04-12-2016, 12:10 PM
dbarnhart's Avatar
Thank you. In the 'old days' when my 1993 Mercedes-Benz 300E had an intermittent hard-starting problem, I got out the wiring diagram. I traced the problem down to being one of two relays. I swapped them both out and eliminated the problem.
With no service manual however, that's impossible to do.:-(
