parking brake adjustment
Old 11-06-2016, 02:05 PM
bbmass's Avatar
Hi, I searched first and can't find any info on adjusting the parking brake. I failed inspection, so got to get it done. The older RDX has an internal and external adjustment. Is there an internal adjustment on the newer one or do I have to take the tires off? Thanks
Old 11-06-2016, 07:10 PM
Brown13's Avatar
I tried this on My 2013 and it is the same.
Old 12-07-2016, 07:35 AM
Joe Las Vegas's Avatar
Is the parking brake on one wheel or two?
Old 12-07-2016, 07:47 AM
Received 8,584 Likes on 6,630 Posts
two..
Joe Las Vegas (12-07-2016)
Old 12-07-2016, 03:08 PM
two..
I have to do it then, my parking brake only locks the left rear wheel.
Old 12-07-2016, 03:37 PM
dirleton's Avatar
What do you suppose the dealer gets for adjustment? I think "check adjustment" is part of B1.
Old 12-07-2016, 03:40 PM
Probably 1 hr labor, same as changing a cabin air filter, even though it takes 3 minutes to do, all shops charge 1 hr min.
My pedal clicks 10 times, will do it soon, it's a DIY job.
Old 12-07-2016, 04:24 PM
Mine doesn't have the adjusting screw at the pedal, must be because I have an early built RDX. I'll adjust at the wheels, I'll press the pedal 5 clicks and adjust the rear wheels until they don't turn anymore and see if it will be enough, I'll go by trial and error until it locks using only 5-7 clicks on the pedal, I'll do it in a few weeks when I put on the KYB shocks.
Old 12-07-2016, 04:30 PM
dirleton's Avatar
My dealer charges $85 to swap both filters, including parts.
Old 12-31-2016, 06:44 PM
I just adjusted my parking brakes, like in the video, jacked it up in the middle and removed both rear wheels, but here's a tip to make it easy, put 3 clicks on the parking brake pedal, then adjust to make it so that you can barely turn the wheel hubs by grabbing onto the bolts (use gloves), then it will result in 5 clicks once the car is done (6 clicks if you push real hard).
fafpak
60
03-15-2021 11:42 PM
MGK
08-10-2016 07:38 PM
MikeRadio
5G TLX Problems & Fixes
18
04-18-2016 01:32 PM
mossman77
04-12-2016 09:17 AM
Quick Reply: parking brake adjustment
