Key Fob Help
Key Fob Help
Hi everyone i recently machine washed one of my key set, which had my Acura key fob on it, yes stupidity of mine. Currently the key kinda works, when i mean kinda half of the functions work. None of the buttons on the fob works but the vehicle still recognizes the key in its proximity. When inside a hand full times the car will start.
I open the actual key fob and it doesnt seem like and rust has formed. When inserting a battery the red led turns on for a couple seconds then turns off.
Any recommendations they get this back up and running? I know with some other brands you can add a fob if you have two fobs already. Can you do that with Acrua? How much would a different fob? Does i have to be new?d
I havent called the dealership but im already thinking it will be up the arse.
Dry out the fob entirely by removing the battery, wrapping it in a Kleenex and putting it into a Ziploc bag with uncooked rice. Leave it for a few days.
Once dry, use a new battery and see if it works. If not, then you'll most likely need a new key.
You cannot use a "used" fob. It has to be new and will need to be programmed by the dealer.
Yes, it will be expensive, let's hope that the rice and new battery work.
First, that would be warranty fraud. Secondly, if you removed all traces of water then the fob would work. If water damages electronics then there always is evidence.
Hi Guys.. I'm new here.. Just picked up a 2016 RDX. Our fob keeps beeping even though we are in the house. We checked to make sure all doors and shut and locked. What am I missing?! Thanks!
The fob or the car keeps beeping? If it's the car, maybe you left the engine on.
soupi
14
11-15-2015 11:15 AM
