Key Fob Help
Old 05-28-2015, 08:47 PM
ipodnag's Avatar
Key Fob Help
Hi everyone i recently machine washed one of my key set, which had my Acura key fob on it, yes stupidity of mine. Currently the key kinda works, when i mean kinda half of the functions work. None of the buttons on the fob works but the vehicle still recognizes the key in its proximity. When inside a hand full times the car will start.
I open the actual key fob and it doesnt seem like and rust has formed. When inserting a battery the red led turns on for a couple seconds then turns off.
Any recommendations they get this back up and running? I know with some other brands you can add a fob if you have two fobs already. Can you do that with Acrua? How much would a different fob? Does i have to be new?d
I havent called the dealership but im already thinking it will be up the arse.
Old 05-29-2015, 05:23 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
A few things you can try:
Dry out the fob entirely by removing the battery, wrapping it in a Kleenex and putting it into a Ziploc bag with uncooked rice. Leave it for a few days.
Once dry, use a new battery and see if it works. If not, then you'll most likely need a new key.
You cannot use a "used" fob. It has to be new and will need to be programmed by the dealer.
Yes, it will be expensive, let's hope that the rice and new battery work.
Old 07-20-2015, 08:48 PM
RSX_Takashi's Avatar
Well, if you can remove all traces of water, may be you can bring it to the dealership and have them replace it under warranty.
Old 07-21-2015, 02:08 PM
ceb
ceb's Avatar
First, that would be warranty fraud. Secondly, if you removed all traces of water then the fob would work. If water damages electronics then there always is evidence.
Old 12-21-2015, 12:04 AM
Phillywood's Avatar
Hi Guys.. I'm new here.. Just picked up a 2016 RDX. Our fob keeps beeping even though we are in the house. We checked to make sure all doors and shut and locked. What am I missing?! Thanks!
Old 12-22-2015, 03:36 AM
Desert Ridge's Avatar
I've never, ever heard a noise come out of my key fob.
Old 07-08-2016, 10:51 PM
Nitefall's Avatar
i haven't either...
Old 07-30-2016, 12:23 PM
Al Dente's Avatar
The fob or the car keeps beeping? If it's the car, maybe you left the engine on.
datadr
03-23-2016 01:39 PM
soupi
14
11-15-2015 11:15 AM
eastcoastguy
10-29-2015 03:00 PM
DementiaPhuro
09-29-2015 05:31 PM
malvothegreat
09-29-2015 12:38 AM
Quick Reply: Key Fob Help
