Acura V6, P1705, P1706, P1709 and Diagnosis Tree
Old 02-03-2013, 11:49 PM
spydercatt's Avatar
This is a link to a video to replace the transmission range switch/neutral safety switch. In the description there are links to a diagnosis tree if you need more help.
Old 07-24-2013, 06:03 PM
types_01's Avatar
P1709 code
I spilt coffee on my shifter tdy. when I turned my car on I got A D5 Blinking, Hazard light is on, Check Engine is on....
All my Gears work no problem driving but all those lights r on..
so I went to auto zone to check the code they said code
P1709
Auto Shift manual
Mode Circuit or upshift switch Circuit or down shift Circuit switch
I don't know what to do or what that means someone help please!!
Old 07-24-2013, 08:36 PM
Dorsey's Avatar
Take it to the dealer and pay to get it fixed if they don't fix it under warranty (doubtful because of the spill). Autozone is giving you the trouble code that resulted from the problem and is stored in the control module (the cars "computer"). The problem with these generic codes is that in many cases they don't really pinpoint the problem. The dealers have tech machines that read subcodes that are much more definitive and help them find the cause much quicker. In your case, it may be that a connector needs to be dried or you could have damaged an electrical component. It will be much quicker and perhaps less expensive if you let the dealer pinpoint the problem than if you start replacing components based on the autozone code reader.
Old 11-03-2013, 07:07 PM
5th Gear
Red Basquer's Avatar
Gotta love the dealer tech trap.
Laoch
1G RL (1996-2004)
10-02-2015 03:27 PM
sockr1
10-01-2015 01:31 AM
asahrts
09-04-2015 05:55 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: Acura V6, P1705, P1706, P1709 and Diagnosis Tree
