2014 RDX With Tech Map light replacement - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 05-17-2015, 05:52 PM   #1
New Member
I have a 2014 RDX with Tech and have replaced nearly all of the interior bulbs with led's.
I can't figure out how to change out the factory supplied led map lights, they are dingy yellow as compared with the xenon white 6000k I'm using everywhere else.
What is the bulb or lamp type number that I can replace the with, and is it possible to change them out?
Thanks in advance
kjsand1
2014 RDX With Tech
Silver Moon/Ebony
Front tint to match rear
WeatherTech's
kjsand1 is offline   Reply With Quote
Old 07-23-2015, 08:39 AM   #2
Registered Member
thephantom's Avatar
You can't replace those. They are embedded in the board.
thephantom is offline   Reply With Quote
Old 11-02-2015, 10:43 PM   #3
New Member
kjsand1: Just a question for you, since you own the same model year. I just post this msg earlier "On my 2014 RDX w/Tech Pkg, my backup camera display showed brown in color when back up to green grass area." Do you have the same experience on 2014 RDX W/Tech Pkg.
charlie01 is offline   Reply With Quote
Old 11-16-2015, 11:52 AM   #4
Registered Member
Quote:
what does that mean "Embedded into the board" ? Are they LEDs? Because they really don't look like LEDs.
JACN is offline   Reply With Quote
Old 01-22-2016, 11:14 AM   #5
Registered Member
thephantom's Avatar
Quote:
They are but a warmer temp, perhaps 3000K. The bulbs (individual LED's) are soldered onto the board so you'll have to use a soldering gun to remove the bulbs... too much work for me to take on.
Old 08-25-2016, 10:31 PM   #6
Registered Member
I hate the map lights. All my lights are 5k temp and the map lights throw it off. Other than unplugging, does anyone know how to turn off the map lights?
BooBooKaki is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Triangle with "!" at startup, and VSA light after 30-40mph. Help! mada51589 3G TL Problems & Fixes 50 01-19-2017 01:13 PM
Tail Light Cover Question wusty23jd 3G TL Audio, Bluetooth, Electronics & Navigation 4 09-24-2015 11:41 AM
Is there a Rear Seat Back Protector for the RDX? d.lim Second Generation RDX (2013+) 10 09-15-2015 08:54 PM
What are the empty spaces next to my traction control button? Charlespsu Second Generation RDX (2013+) 3 09-02-2015 09:54 AM
A1 Service - Dealer or Local Garage? emsrph Second Generation RDX (2013+) 3 08-31-2015 10:28 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
