Here is your ANC Module location!!!
Old 10-22-2016, 12:45 PM
7th Gear
RDXSUB's Avatar
Not sure if this is well known or not but this took me hours to track down.. This is the ANC module you need to unplug if you run an aftermarket subwoofer to avoid the annoying random Bass notes. I have not confirmed that BT calling is still working yet.. I am hoping it still does. This did however fix my subwoofer buzzing issue with my aftermarket system. Turning it off at the radio setting did not stay and had to be done every time we started the RDX.
SkylineEX-S (10-24-2016)
Old 10-22-2016, 11:22 PM
The Original Shawdy
carbonTSEX's Avatar
I have been dealing with this issue for a year now in my wife's 16 RDX. I installed a JL Audio W6v2 with JL Audio 500/1v2 amp and had this issue. Upgraded to W6V3 sub and 600/1v3 with LC2 and bass knob. Still didn't fix the random bass tones. If this is the answer, I will be forbeber thankful as well as my wife. I'm gonna go try it right now lol.
Let me know if this fixed your issue.
Old 10-23-2016, 12:16 AM
The Original Shawdy
carbonTSEX's Avatar
What exactly does that plug control?
Old 11-04-2016, 10:21 PM
The Original Shawdy
carbonTSEX's Avatar
Tried this with no luck. Still has the same issue.
Old 11-08-2016, 08:40 AM
SkylineEX-S's Avatar
It didn't affect anything when you unplugged the module???
Old 11-08-2016, 09:11 PM
The Original Shawdy
carbonTSEX's Avatar
I'm sure it affects something but I had unplugged it, started the car and heard the thumping so I plugged it back in.
I want to find a solution to this though. I have a bass knob added to my LC2 so I have it turned all the way down and the thumping is minimized but not obsolete. Then I can crank it up and it works fine. It's just after start up the issue arises.
Old 11-09-2016, 12:09 PM
The search continues...
carbonTSEX (11-10-2016)
Old 11-17-2016, 03:37 PM
Skidoor's Avatar
RDXSUB, you seem to have vanished, I'm sure some of us want to know if unplugging the ANC module also eliminated bluetooth function. Are you still rocking out with good bass from your aftermarket sub?
What source did you use for your amp input? The factory sub wires?
RedneckCPA
05-22-2021 06:55 PM
Steven Chan
03-09-2021 06:48 PM
MikeILX
ILX
07-07-2018 10:49 AM
GameOver69
09-28-2016 08:49 AM
slickrab
05-09-2016 09:37 PM
Quick Reply: Here is your ANC Module location!!!
