Hardwiring blackvue dashcam - which fuses to tap?
Old 09-25-2015, 10:12 PM
2021 RDX A SPEC
Acura604's Avatar
Installing power magic with black vue.
Black is ground
If anyone has done this install, where did you tap the red and yellow wires under the dash fuse box?
Red is ACC - provides power when ignition on
yellow is goes to a fuse that's always on.
Old 11-11-2015, 04:54 PM
PeteZ28's Avatar
If time permits, I will be doing this very thing this weekend. I will update this thread whenever I do.
Old 11-14-2015, 10:22 PM
PeteZ28's Avatar
I used fuse 12, the "Accessory Power Socket (Center Console)", for yellow and fuse 23, "Option" (AWD) for the red.
Old 11-14-2015, 10:54 PM
2021 RDX A SPEC
Acura604's Avatar
Thanks Pete...ill get to this tomorrow. Where did you ground the black wire ?
Old 11-15-2015, 11:11 AM
PeteZ28's Avatar
Behind the e-brake cable.
Old 11-15-2015, 11:19 AM
PeteZ28's Avatar
All of the excess wire and the lighter plug fit easily behind the kick panel. I mounted the power pro with the provided double sided tape.
Old 11-15-2015, 01:43 PM
2021 RDX A SPEC
Acura604's Avatar
Thanks for the pix!
and looks like you used 'low profile' fuse taps.
Old 11-15-2015, 03:22 PM
PeteZ28's Avatar
Whatever was on the shelf at NAPA! :-) hope that helped.
Old 11-15-2015, 04:43 PM
2021 RDX A SPEC
Acura604's Avatar
One last thing....your dip switch settings on your power magic? Thanks.
Old 11-15-2015, 05:55 PM
PeteZ28's Avatar
12 volt, 120 minutes. Seems to be ok in this 30-50 degree weather.
Old 02-01-2016, 06:17 PM
8th Gear
hulksmash604's Avatar
Was searching for this, thank you!
PeteZ28 (02-01-2016)
Old 02-01-2016, 09:18 PM
PeteZ28's Avatar
Welcome Hulk!
Old 02-01-2016, 09:25 PM
01acls's Avatar
FYI
The "Add a Circuit/Tap a Fuse" is rated at a maximum of 10 amps (the one in your pics above). The Accessorizes Power Socket - #12 is rated at 15 amps. By over loading the Add a Circuit, that is a fire hazard lying in dormant. All it takes is the perfect storm to come alone an activate all 15 amps and then you might see your car go up in smoke. I'm sure you wouldn't want to see that happen, just saying.
You might want to move it to another circuit that's rated at 10 amps or less.
Old 02-01-2016, 09:36 PM
PeteZ28's Avatar
Good catch! I have it tapped into the center console accessory socket, and used a 10A fuse in the add a circuit, so no issue, but you're very right, it could be. Thanks for pointing that out.
Old 02-01-2016, 09:47 PM
01acls's Avatar
No, the Add a Circuit itself is rated at 10 amps combined (both circuits) so it will be over loaded if you reinstall the #12 - 15 amp fuse back like it's suppose to or if the two circuits draw more than 10 amps.
ie. 7 amps + 7 amps = 14 amps
It's rated at a maximum of 10 amps, not 10 amps each.
Old 02-01-2016, 10:12 PM
01acls's Avatar
Correction, my post above is incorrect. It is 10 amps per circuit bc they are two separate circuits.
However, the Accessories circuit is 15 amps so that circuit still can be overloaded.
Old 03-09-2016, 05:01 PM
2021 RDX A SPEC
Acura604's Avatar
hey guys...any updates on this? as in, what fuses are safe to tap into for powermagic operation? Thanks.
Old 03-09-2016, 05:06 PM
8th Gear
I did this install on a 1G TSX and a 3G TL, I used the ACC fuse for ACC+ (5A.. i think.. might be 10A) and the Sunroof fuse (20A) for Batt constant.
Ground to the frame of the car somewhere, I found a screw near the hood release on both cars, quite a PITA to get to, but it works.
Good luck!
Old 03-21-2016, 03:17 PM
2021 RDX A SPEC
Acura604's Avatar
ooof. holy crap how did u loosen the bolt to attach the ground wire.... ugh.. my socket set cant do it... may have to use a wrench.
Old 03-21-2016, 03:25 PM
8th Gear
I used a wrench, and some old school muscle!
Use a short pipe around the wrench for extra leverage. Or just more a bit more ooomph!
haha good luck!
Old 08-05-2017, 12:55 AM
08 PMM/Black Tech
cFoo's Avatar
Just in case anyone is trying fuse #23. It's listed as Option but for my 2017 that's the fuse for LKAS, BSI, and RDM. I tapped into it and the car was not happy. It detected the new load and kept all the sensors off. It went back to normal after I plugged the original fuse back in.
soupi
14
11-15-2015 11:15 AM
Skirmich
10-01-2015 12:59 PM
xsilverhawkx
09-28-2015 06:51 PM
ripit
09-26-2015 06:19 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Hardwiring blackvue dashcam - which fuses to tap?
