D5 Flashing...
Old 09-04-2005, 02:08 PM
Diablo2233's Avatar
Unhappy D5 Flashing...
so just when i thought everything was going fine with my used CL-s, the D-5 flashes maybe...once a week and whenever you switch to another gear it just stays flashing. One time i stoped at a stop sign and put it in park and restarted my car and it went away, soo basically im woundering if i should really worry about the trans or is it just electrical....
Old 09-04-2005, 06:29 PM
I'm a Vagiterian.
All Mine's Avatar
Dang. When it's flashing, does it go into 5th gear?
Old 09-04-2005, 10:19 PM
Beware of leakage
Chopsie's Avatar
Run for the hills, thats a tranny warning I believe. I remember seeing that "symptom" somewhere around here.
Old 09-04-2005, 10:34 PM
Masshole
RMLatinplaya's Avatar
Mines started doing the same thing. I had it checked out and they told me it was the Automatic Transmission Fluid Temperature Sensor which was like $70. OBDII Code 0710
Old 09-04-2005, 11:56 PM
mrsteve's Avatar
Take it in
Old 09-05-2005, 09:37 AM
Diablo2233's Avatar
no it doesnt go into 5th gear it normally shifts its just weird
Old 09-05-2005, 01:26 PM
louisn's Avatar
Question
Say, WHAT?
I don't understand!!!!!!!!!!!!!!!!!
Old 09-05-2005, 02:29 PM
Diablo2233's Avatar
basically... as soon as i put the key into the ignition D5 comes on and starts flashing green even while in park, reverse...anything and it flashes while driving in D5 as well, when it does this it doesnt pick up as well...i guess but that might just be mental
Old 09-06-2005, 01:11 AM
wilp99's Avatar
have your obd2 codes scanned at autozone. its free. and it will tell you what the light is on for. does ss mode still work?
Old 09-06-2005, 06:33 PM
Diablo2233's Avatar
ya it works, i have a feeling its trans fluid because of the milage (71k) so im taking it in this weekend
Old 09-06-2005, 08:13 PM
Turbo + Sound = Hey-pee
kensukikatayo's Avatar
That makes me worried... Time to get my trans fluid changed too...
Old 09-06-2005, 10:44 PM
civicking's Avatar
you guys are waiting that long to change the fluid, wow i get mine changed about once a year, there is only a screen filter is these transmissions and its not changed when the fluid is replaced, so it has to be done more often. no wonder your trans is doing weird things, and also seeing as that auto trans on the cl runs hotter then normal it tends to burn the fluid fater. also remember to use only honda fluid nothing else, if you do it will ruin the clutches in the trans, i heard that it will melt the glue that holds the clutches to the metal and they come clean off.
Old 09-07-2005, 12:08 AM
That statement brings chills down my spine and nasty images into my head... AHHHHH!!!!!
Old 08-06-2006, 02:31 AM
Health's Angels
GINge!'s Avatar
Heya, same thing here. Flashing D5, had the code checked and its a bad ATF temp sensor. Cost me $75 just for that :-/
Anyways, I was quoted $400 to replace the sensor. I asked the tech what are the implications of NOT replacing the sensor, since they told me it was still OK to drive the car with the flashing D5. He told me that the D5 light would continue flashing, and said there is nothing wrong with the transmission.
This does not give me a warm fuzzy feeling. I don't want to pay $400 to stop a stupid light from flashing, if that is all it really does...
Old 08-09-2006, 09:40 PM
wilp99's Avatar
if you dont change it the car will try to stay in a higher gear longer than it needs to be.. thinkin it needs to warm itself up.
also earlier someone said theres a screen filter in these trannies.. well there is a fiber filter inside like most trannies but you have to take the tranny apart to get to it. so your kind of right by sayin theres no filter.
oh yea use only honda ztf tranny fluid. or redline (i heard it works pretty good)
Old 08-10-2006, 07:55 AM
Health's Angels
GINge!'s Avatar
hey, thanks, that's exactly what it started doing yesterday. I'm going to the stealer to get it fixed tomorrow.
Old 11-24-2006, 05:07 PM
Senior Airman
slowcl-s's Avatar
Your tranny is gonna blow!
Read the Manual... it says it does flashes before it fucks you!
Old 11-24-2006, 05:16 PM
BLKCLP's Avatar
Been there, done that. time for new tranny buddy.
Old 11-24-2006, 09:11 PM
Dead-Fox's Avatar
This thread is 3 months old.
Old 11-25-2006, 12:07 PM
Health's Angels
GINge!'s Avatar
was fixed 3 months ago and is fine now.
Old 03-10-2017, 07:07 AM
Reggienoah1238's Avatar
My 2004 Acura MDX
In D5 my mdx started flashing does anyone know what is going on/happening?
Old 01-13-2018, 07:12 PM
Eic0826's Avatar
[QUOTE = Reggienoah1238; 15976095] En D5 mi mdx comenzó a parpadear, ¿alguien sabe qué está pasando / sucediendo? [/ QUOTE]
my 2004 Mdx has the same problem, but I don't know what I can do, I replace the spark plugs, egr valve, belt and continue flashing I don't have more money for repair my car the mechanic told me is the battery because the battery don't have the correct percent for the electricity of the car need but I don't know, you find the problem in your car?
bigg_86
03-17-2015 09:25 PM
brianch
08-30-2013 10:45 AM
shaddyprynce
08-13-2012 09:35 AM
aimmaster
14
02-01-2011 07:51 AM
Quick Reply: D5 Flashing...
