Will this set up rub?! Details inside!
Old 01-28-2009, 01:07 AM
TheDonks_03CL's Avatar
I am lowered on eibach prokit and running 2005 TL Wheels with 235-45-17 and rubbing, so so annoying.
I plan on buying 2003 cl-s rims and running 215-45-17 for a more comfy ride.
Will this new set up rub?
Thanks Guys!
Old 01-28-2009, 01:11 AM
combat mediC's Avatar
It may rub, but it'll be better.... wheres philip?
Old 01-28-2009, 01:21 AM
Unregistered user
LIPPSTUH's Avatar
no
Old 01-28-2009, 01:36 AM
Unregistered user
LIPPSTUH's Avatar
if so roll fenders
Old 01-28-2009, 08:11 AM
*6MT*
alxmlr789's Avatar
I've got some for sale...
PM me if ineterested.
Old 01-28-2009, 09:22 AM
p.diddy's Avatar
how are you rubbing i used to have that same setup and i never rubbed.
Old 01-28-2009, 02:34 PM
Yeah the rear wheels rub alot, everytime i go over a bump or turn a corner real tight it rubs like crazy.
Its so so annoying, and with the TL wheels it sticks out too much, i dont like the looks of it.
Thats why im going with the 03-tls wheels or the 17" HFP Honda Accord rims
Old 01-28-2009, 03:15 PM
dru2's Avatar
I'm slammed on OEM CL-S rims with 235/45/17
ZERO rubbing.
Old 01-28-2009, 04:24 PM
ZERO rubbing.
Thats good to know!
I think im going to go with 215 45 17 when i get my summer rims
Old 01-28-2009, 06:13 PM
monkeybutt's Avatar
Thanks Guys!
Your present 235/45/17 tires will be more comfortable than comparable 215/45/17 size tires by virtue of taller sidewall and more volume. If you switch to '03 CL-S wheels (17x7, 55 offset) there will be no rubbing. I've run 235/45/17 and 225/45/17s w/ these wheels and will now choose 235 as the speedo is correct and the revs more sedate when cruising in sixth gear.
Old 01-28-2009, 09:48 PM
02CL-TypeS's Avatar
that sucks bro. Why not keep the wheels which look better then the 03's and change the springs. I've got 05 TL wheels lowered with H&R Sport springs 1.75F/1.5R and no rub
-You can also put some smaller tires on your TL rims...you can even get by with 215/45/17's on your wheels...i've done it for a while
Old 01-28-2009, 11:08 PM
Im not sure I like the 05 TL wheels because it sticks out too much from the fenders, I want something nice and tucked.
How does 225-50-17 Sound?
Old 01-29-2009, 02:45 PM
02CL-TypeS's Avatar
225-50-17 shouldn't rub. Thats the size I'm getting for my 05 TL rims when my 215/50/17's are worn. I guess its personal preference, but I like the offset of the 05 TL rims on the CL...makes it look more aggressive
Old 01-29-2009, 03:26 PM
Missing My CL-S
SG81's Avatar
how much of a drop do those springs give you? i'm lowered, not slammed on H&R's w/ 235/45/17 and no rubbing
Old 01-29-2009, 04:48 PM
I only rub in the back when i go over bumps and sharp turns. But still its so friggin annoying!
Old 01-29-2009, 08:11 PM
3.5 psi
gnuts's Avatar
are your fenders rolled? If not, roll them, and you shouldn't have any problemos.
Old 01-29-2009, 09:23 PM
This might sound like a dumb question, but how do i roll my fenders? This might be the best solution.
But still I dont like how the TL wheels stick out so far from the fender.
Old 01-30-2009, 07:12 AM
3.5 psi
gnuts's Avatar
Well the oem cl wheels are too narrow in my opinion. Those TL wheels look much better. They shouldn't stick out past the fender. You should be able to still slam the car with those wheels...so they're still inside the fender.
You can go to shop to have your fenders rolled - just your rears. Probably a performace shop. You can also rent the fender roller from some places, or you can use the baseball bat method. Heat up the fender lip with a heat gun just enough to make the metal malleable. Then use the bat to roll and push back the fender lip (fold it up).
Old 01-30-2009, 10:07 AM
Missing My CL-S
SG81's Avatar
gnuts, do you know what local shops charge to roll the fenders around here?
Old 01-30-2009, 12:29 PM
3.5 psi
gnuts's Avatar
I'm not sure. I'm thinking that if i get a new suspension setup in the summer i'll do it myself. I'm sure places like 360 Auto would do it. Can't see it being that much though.
Old 02-05-2009, 11:01 PM
illson20's Avatar
hmmm, looks like offset on that wheel is +45 (the TL wheel), that is supposed to be min acceptable for our cls. You are still rubbing with those on an eibach pro drop? I'm running an eibach pro kit now and am getting rid of my rims now for rubbing issues to pick up some 19 x 8.5" +45s with 235/35/19 tires.... Wonder if I'll still run in to problems without a fender roll...
09-17-2015 10:16 AM
JnC
09-11-2015 06:06 AM
braveheart
09-07-2015 08:12 AM
asahrts
09-04-2015 05:55 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: Will this set up rub?! Details inside!
